Home > Technical (L322) > New RR owner with a few issues. Begging for advice |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 |
first thing to do is dis-connect the battery after the range has fallen asleep , then leave for about 30 mins and re-connect...after re-connection, turn the steering wheel fully left then full right, hopefully your suspension error will go and the sat nav will be ok...if not let us know and we'll start scratching our heads trying to help you... ... - .- -.
29th Oct 2011 12:05pm |
Have a look at Marsie' 3 days of ownership thread. Sounds like you could have similar issues. Battery new/old contact surfaces of the battery poles clean ???? etc. MY 2010 5.0 SC Galway green and sand interior!!
29th Oct 2011 1:43pm |
Matt@obsidian Member Since: 29 Oct 2011 Location: Greater Manchester Posts: 70 |
Cheers guys. I had found the tip of disconnecting the battery but didn't realise you had to leave it o long. I did it for a couple of minutes? Also the sat nav unit (at the rear) appears to be dead completely(no power light). Wondering if that's maybe a fuse? |
29th Oct 2011 2:54pm |
it could be a fuse, if you download 'rave' this will help you pin point the correct one..
29th Oct 2011 4:41pm |
Guys thanks for all the advice so far. Update, I have managed to remove the "suspension inactive" warning from the dash, and the deity gear is working as it should but the vehicle won't rise or drop? Although there is now no notice there is clearly an issue. What do we think? Pump? |
30th Oct 2011 8:51pm |
Another update. Suspension sorted. Needed new compressor as suspected. Get to pick it back up Saturday so I can finally get round to detailing it. Got a LOOOOT of paint correction to get through
10th Nov 2011 10:38pm |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
Glad its almost sorted, make sure you post pics of the paint correction
10th Nov 2011 10:44pm |
10th Nov 2011 11:20pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 |
Re the Sat Nav, its quite easy to access, check the fuse, check the connections, check for moisture in the back left compartment. Is the disc in the machine?
11th Nov 2011 9:26am |
Thanks for the reply. The nav was addressed in another thread also. I had checked fuses and checked the unit itself to find it sodden. Googled to find the "rear water ingreess" issue. I must say it is a complete let down that an issue like this exists let alone it being so common it has a name. And a water shedder is not a good enough solution for me, my navigation is not the problem, the fact my car let's in water is. You can by a never before heard of car and that won't let in water something that was 70k new definitely shouldn't lol. The garage that's done the suspension thinks they have found 2 areas of concern which they are trying to remedy. Do you have any input as to where the issue lies perhaps. If so I can forward that to the garage it would be a big help. I am sure given its such a widespread and large problem it must have been investigated in house?
11th Nov 2011 9:52am |
