![]() | Home > General > do you like your back end exposed. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35508 ![]() ![]() |
keep noticing that the back underside of the range is sort of un-finished and a bit ugly looking so i was wondering if theres a bit of aftermarket plastic that can be bolted on to give it a smoother look.. ... - .- -.
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
best thing to do is keep the exhaust system clean and painted. Mine was looking good until I got the pressure washer under there to blast some dirt off. Damn thing took some paint off as well and it now looks alittle naff. FFRR TD6 HSE
i did the same , painted everything in view but it soon gets dirty.. |
prob best waiting until next spring now as anything you clean under there now won't stay clean for long.
I cleaned mine although on the later versions it doesnt appear to be as exposed as the earlier versions. Scarey if you clean it and spray it with WD40 it keeps it looking good and the WD40 prevents a lot of the crap from sticking. |
i'll try that mate |
yeah, I'm gunna try that as well.
Scarey / Greg good thing is with the WD40 also is you dont really need to clean it as spraying it on is simple and takes a few minutes even hides dirt if you cant be bothered cleaning it |
I also am a lot happier with my tow bar in place (it came with the swan neck but I fitted the two bolt flange type so I could use my bike rack with it). Gives me an extra sense of security against those approaching too fast from behind! .
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 ![]() ![]() ![]() |
Followed a rangie today with overfinch badging on it (was a pre facelift like mine) and that had a lower section under the bumper and the exhaust pipes poked through? Paul
that one in pic 1 is a nice solution, you'd have to cut and extend the pipes as well i suppose... ... - .- -.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Cant be to hard can it? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
You dont need to as they are designed to take the standard exhaust downswept end pipes, but yes you can cut and extend them or fit dummy ones or have none on display... Thats the beauty of this undertray Stan...
very nice craig , thanks for the pics.. ... - .- -.
