Home > For Sale & Wanted > FS: Surround sound system
mzplcg
OK, I've not used this in 2 years so might as well offer it up here.
Surround amplifier as in picture below. All the usual Dolby stuff, pokey amplifier so sounds great.
Set of 5 speakers, Bowers & Wilkins. 2 front towers, approx 3 foot high, 1 centre channel and 2 rears with dedicated stands.
This lot cost me over 3 grand when I bought it so I reckon 500 quid is reasonable.
Will try and get some more pics up. Might listen to offers, then again, might not. Laughing
Front speakers look like these.
For the techie stuff, I found this on tinternet
High quality, THX Select certified, the VSX-AX3 is a powerful A/V receiver, built according to Pioneer's Advanced Multi-channel Stereophonic Philosophy. This means that this amp's design adapts certain AIR Studios' professional sound engineering principles to the home environment. Besides AIR Studios fine-tuning, the VSX-AX3 features the Pioneer exclusive Advanced Direct Energy MOS FET circuitry, ensuring a stable sound image and strong drivability for all 7 channels — each with a power output of 100 W. And with the Automatic Multi-Channel Acoustic Calibration(MCACC) system with microphone, it will seem like one of the professionals from AIR Studios is adjusting the sound in your living room.
The VSA-AX3's advanced 3-D Space frame construction, designed to enhance high fidelity audio, includes an isolated chamber construction as well as direct construction for optimal energy and signal flow. With the 192 kHz/24-bit DAC, you are ensured of a perfect signal conversion. The
VSA-AX3 is compatible with the latest surround sound formats, such as DTS 96/24, THX Surround EX/Dolby Digital EX, DTS ES Discrete, DTS NEO:6 and Pro Logic II. Surround sound modes are plentiful, including Virtual Surround Back for an even more impressive sound experience without having to add more speakers, while the courteous Midnight Listening mode stands for clear sound even at low volumes.
SpecificationsMain Features VSX-AX3-S
On-Screen Display (GUI) Yes
Remote Control Preset & Learning
Dimensions (W x H x D) 420 x 188 x 464 mm
Surround Sound Formats VSX-AX3-S
Dolby Digital Yes
Dolby Digital EX Yes
Dolby Pro Logic Yes
Dolby Pro Logic II Yes
DTS Yes
DTS-ES Matrix 6.1 Yes
DTS Neo: 6 Yes
DTS 96/24 Yes
Surround Modes Virtual surround back
Advanced Cinema: ACTION, MUSICAL, DRAMA, SCI-FI, MONOFILM, 5-D/7-D THEATER
Advanced Concert: CLASSICAL, CHAMBER, JAZZ, ROCK, DANCE
Power Output VSX-AX3-S
Rated Power Output 100 W + 100 W (20Hz - 20kHz, 0.09%, 8 Ohm)
Input (Sensitivity/Imp.): LINE 335 mV / 47 kOhm
Frequency Response: LINE 5 - 100 000 Hz, +0 / -3 dB
Signal-to-Noise Ratio: LINE (DIN) 92 / 65 dB
Construction VSX-AX3-S
Digital Signal Processor Motorola 150 MIPS 48-bit Processing x 2
Amplifier Specifications VSX-AX3-S
D/A Converter 192 kHZ/24-Bit
A/D Converter 96 kHz/24-Bit (2-channel)
Input & Output connections VSX-AX3-S
Digital Coaxial Input 2
Multi-Channel Input 7.1 ch
Pre-amp Output Yes, All (7.1 ch)
Speaker A/B Versatile speaker configuration
S-Video Input/Output 5/3 (Includes Front in)
Audio Features VSX-AX3-S
Bass/Treble Tone Controls Yes
Loudness Yes
Midnight Listening Mode Yes
Source Direct Yes
Post #89218 27th Oct 2011 7:40pm
