Home > Technical (L322) > torque converter
daveo
torque converter
hi all, just had the torque replaced on my FFRR, thought i would share a few things with you all, it started with a very light shudder at around 30mph and you only would get it if you was very light on the throttle, this was the clutch trying to lock up in the converter, it was a bit like going over a cattle grid but not as bad, i caught it very early and was told it will get worse. but if left could and most likely would kill the box as well as it disintegrated. now if you have a warranty it will not cover it, they will ask for the converter to be cut open and send there man down who will look straight at the clutch and cal the "wear and tear card" 40,000 is not high mileage so how can it be w&t, the are sealed for life you may think,yes they agree its low mileage they say, then they put it down to a manufacture fault. you will get no further believe me.
so if you have one of those warranties check with them to see if they will cover it,
daveo
Post #8880 29th Nov 2009 9:38pm
The doc
2008 Range Rover Vogue TDV8 Java Black
Get yourself a warranty from these guys - I have two with them and there great - includes wear and tear.
http://www.warrantydirect.co.uk/wear.html '09 Freelander 2 TD4 HSE Auto for the Mrs
Using the works Fiesta 1.6 TDCI Sport Van - CHROME FREE THOUGH
Searching for a nice E63 AMG or S8 V10 to replace my "wonky" TDV8
Post #8882 29th Nov 2009 11:24pm
daveo
hi thanks, would that be two torque converters or warrantys...
daveo
Post #8883 30th Nov 2009 6:53am
andyw
England 2002 Range Rover HSE 4.4 V8 Zermatt Silver
hi daveo
mine has just started to do exactly that Big Cry
looking at the rave the gearbox has to be taken out etc
was the job expensive in the grand scheme of things and is it a indie or dealer issue cheers Thumbs Up 02 Range Rover HSE Zambezie silver 4.4
Post #17630 29th Apr 2010 12:21pm
daveo
hi my one cane to about 1200 pounds, where abouts are you.. V8 facelift Range Rover Autobiography 22" wheels.
Post #17658 29th Apr 2010 3:37pm
andyw
down in surrey woking
why Question
was 1200 at a dealer Crying or Very sad 02 Range Rover HSE Zambezie silver 4.4
Post #17663 29th Apr 2010 4:07pm
daveo
ok, i am in walthamstow, i used a garage that has got technition from stratstones in woodford, they done a wonderfull job, collected and delivered, how bad is the shuddering... V8 facelift Range Rover Autobiography 22" wheels.
Post #17686 29th Apr 2010 8:19pm
andyw
it does shudder after it has warmed up and and only on light throttle, but not all the time did yours make a noise or just the shudder
i appreciate the transfer and gear box needs to be removed and im now shopping around for a deal being as i am tight as. i am also hoping that it will be covered by the warrenty or at least some
did this afect the gear change as in better smoother etc once done
andy 02 Range Rover HSE Zambezie silver 4.4
Post #17701 30th Apr 2010 10:16am
daveo
hi , no noise just lightly shuddered under light throttle, around 25 to 30 mph, after it was done the changers were smother and didn't change up and down so much. sorry to tell you but i don't think the warranty will cover it as they did the same to me, they let the garage strip it all down and then wanted the torque converter cut opened and because there was not broken parts they put it down to wear and tear.. hope this is not the case with yours...they then went on to say that oil and filter ect was not covered so i told them to poke it right up there hole...and paid for it my self..DON'T USE A SECOND HAND CONVERTER.. you could be back to were you started in 6 months...
daveo
oh! p.s. if they do cut it open and then say its were and tear you will pay more for the new unit as you don't have an exchange unit... V8 facelift Range Rover Autobiography 22" wheels.
Post #17709 30th Apr 2010 3:46pm
andyw
good tips thanks
how long did the garrage take
cheers 02 Range Rover HSE Zambezie silver 4.4
Post #17710 30th Apr 2010 4:54pm
jdog30014467
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
rr 4.4 suspected torque converter help !!
hi there im new to this site and not to sure how it works so hopefully am posting in the right place. Here goes ibought my rr 4.4 v8 recently and it vibrates when I get to 25 mph 1500 rpm [ cattlegrid effect ] it only happens at low throtle in third gear but disappears after 40 mph and doesn't happen in manual/sport ive read a lot of these threads and this sounds like torque converter failure ! all my gear changes are fine so im hoping ive caught this problem early. my car has down 125000 miles and I don't think the box has ever been touched before , could anyone tell me the process of how to pinpoint the exact problem pls or any other relevant info would be much appreciated thanks. 2003 range rover se autobiography 4.4 v8
Post #238092 29th Jan 2014 10:03pm
