Home > Maintenance & Mods (L322) > ANSWERED: Fitting instructions for OEM side tubes
A1GSS
I've received the tubes I bought from Alan. Fitting looks as though it should be easy, but I'm obviously missing something as there is no obvious way to attach the inner end of the leg to the car.
Each leg has a pair of bolts outboard *(easy to fit) and a further pair inboard (problem). The inboard pair have to connect to something but for the life of me I can't see what. I may be missing some vital components.
So, I want a picture if anyone has one.
Have done the obvious (wiki and site search) and googled for it but no luck so far.
Help welcome, thanks. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #88293 21st Oct 2011 12:12pm
Googsy
I think fixing points should be located under the plastic sill which needs to be removed as I had to do this on my Disco. Not sure though Whistle
Have a look here may answer your question
http://www.powerfuluk.com/products/range-r...e-kit.html
Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #88295 21st Oct 2011 12:23pm
duckworthparts
Site Sponsor
LR fitting instructions
http://topix.landrover.jlrext.com/topix/co...p;id=64903 You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #88296 21st Oct 2011 12:25pm
A1GSS
Brilliant, thanks Thumbs Up
Looks perfect. I'll take a good look.
Bow down Graham
____
Post #88297 21st Oct 2011 12:27pm
nbunney
Have a look here:
http://topix.landrover.jlrext.com/topix/co...;cat=OWNER
Post #88301 21st Oct 2011 12:31pm
Good set of pics on these docs. I went out and took a couple, but none as good as these! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #88303 21st Oct 2011 12:32pm
A1GSS
Yes, thanks everyone. Thumbs Up
Much appreciated. Graham
____
Post #88304 21st Oct 2011 12:47pm
TugRR
Dan -
This is a great link, thanks !
I've a set of VUB502610 light guards for my 06MY car. I've got everything bar the template where to drill the holes in the wings. I've checked TOPIX which shows it as part of the fixings. Any idea where I can get the template from ? I've asked on FF before, to no avail . . . . .
Cheers
Thumbs Up Where do you go after one of these . . . ?
Post #88306 21st Oct 2011 1:00pm
A1GSS
Right, I've now had a look with the benefit of the photos and the LR instructions. The missing fixings are in fact covered by circular pieces of sticky plastic. Once you know what they are, peeling them of reveals a nice M8 tapped hole Very Happy
Hooray.
Sorted Graham
____
Post #88307 21st Oct 2011 1:30pm
Love it whan a plan comes together! Thumbs Up
I hope you polished them before you fitted? Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #88311 21st Oct 2011 1:49pm
A1GSS
I've had to order up some stainless bolts (and some Autosol...), but they'll be nice and shiny soon. And fitted. Will post a few photies when they're done. Graham
____
Post #88317 21st Oct 2011 2:05pm
Gald it's all sorted. Just be careful, as they get slippy in the rain............ Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #88318 21st Oct 2011 2:07pm
A1GSS
Right, all done. What a complete bastard of a job. One of the M8 nuts welded to the inside of the chassis was impossible to get the bolt into, just wouldn't catch. Eventually did bu was very stiff indeed... resorted to a bit of force and Censored me but the weld holding the nuts onto the inside of the chassis member snapped off...by then the M8 bolt was half way in.. so now I have a loose fitting, with a hugely stiff M8 stainless bolt stuck into a nut loose inside the chassis....
Hacksaw. Not a chance.
Bought a small angle grinder and a stainless cutting disc. 30 seconds later, head is off bolt and I can fish the rest of it out through one of the bigger holes.
Now - how to replace the fixing. Went to a fixings specialist and bought a couple of industrial 6mm self-cutting / self-tapping hex head bolts; small pilot hole then drive these in with a power driver. Two replace one x M8. Probably not perfect but good enough I think.
Fitting time including all the dicking about amounted to 4 hours.
 Graham
____
Post #90519 5th Nov 2011 3:30pm
Hmm, not such an easy job! Censored
Looks good all the same! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #90521 5th Nov 2011 4:07pm
Looking very good Thumbs Up trying to find fitting instructions for OEM sidesteps , if they are easy enough to fit , Dan will be getting a PM Laughing Thumbs Up ====================================
Post #90674 6th Nov 2011 2:10pm
