![]() | Home > Technical (L322) > Water Pump Failure - Not a nice result.... |
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 ![]() ![]() ![]() |
I have recently replaced my water pump. I bought an after market one with an aluminium impeller which IMO is better.
DeltaC Member Since: 22 Mar 2010 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
What make is your aftermarket pump and how much was it, if you don't mind me asking?
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
H'mmmm.... if they are small enough to get through the rad then they are unlikely to have a bird strike effect on the new pump. I suspect they will just be stuck in the gallaries somewhere or at the bottom of the tank.
The two fins that I got back came from behind the pump, in the block which should be where the water comes from to get to the pump. They are half a thumb nail in size but quite hard so if the others have gone in that direction and get picked up by the coolant, they will head to the pump.
The make of the aftermarket pump is First Line, part No.FWP 2181 £72.00 inc vat. Seems to be good quality, time will tell.
Stewart, any feedback on your make of pump?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
if that's eurocarparts that have quoted you then there's a 30% off code here http://www.fullfatrr.com/forum/topic8057.html ... - .- -.
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 ![]() ![]() |
wow that LR one is expensive, PM me your VIN depending on year, its either going to be £125+ or cheaper for a gen pump You can paypal direct using - www.paypal.me/duckworthparts Please supply your full name address when sending a paypal payment. https://www.facebook.com/duckworthparts www.duckworthparts.co.uk My Direct Line: 01673 849873 Email: robin.hall@duckworth.co.uk Supplier of Genuine Land Rover & Jaguar Parts For All Models ![]() |
Pump has done 20000 miles and running fine, would recommend it.
