Home > Technical (L322) > Air pump over run
Johninspain
Air pump over run
Just got the range back after new Battery And alternator as diagnosed on my previous post, the althenator was completely fried !
Anyway it seams that now the pump for the suspension is running longer than befor ? I used to get in and drive off and not hear a thing but now it's pumping even though I'm level if I lower it to access it's fine and it goes up and down ok but it seams to be pumping when it shouldn't ? Any ideas ? Nothing has been touched, just new battery and alternator
Oh what it did do that I have never noticed before was lower the rear when I opened the boot ? ANSI geared a sharp hiss noise ? I wonder if settings have been changed ?
Post #87410 14th Oct 2011 5:32pm
The system dumps air out a valve that is next to the compressor, perfectly normal. There could be a leak in the system causing the pump to run on
Post #87462 14th Oct 2011 8:11pm
Johninspain
It's not loosing any air while stood though it's retaining hight. I have never heard it running before or noticed it drop the rear end when I open the boot
Post #87471 14th Oct 2011 8:53pm
