Home > General > Hypothetically speaking...........
I'm finding that RR ownership is a much more satsifying experience that I originally expected, so looking into the future, and once I no longer have a fuel card, I keep thinking about 2 possibilities :-
1. Keep the S/C and get an LPG conversion, or
2. Get rid and go down the diesel V8 route
Any thoughts on either option? Got - 2017 SDV8 Autobiography in Loire Blue
Post #86821 11th Oct 2011 9:40pm
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
Given you already have the S/C and love it I'd recommend getting it LPGd. That way you can keep the car you love but also not be stung too much with running costs. FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #86827 11th Oct 2011 9:51pm
That's my initial thoughts, especially since I think I've got a good 'un (touch wood), but I just wonder wether Mr Chancellor will start to bump up the tax on LPG, making it less of a saving in years to come? Got - 2017 SDV8 Autobiography in Loire Blue
Post #86829 11th Oct 2011 9:53pm
bozmandb9
Definitely go with the first option! Why would you want to go for an oil burner after enjoying the S/C? Only pain with the LPG'd S/C is the range, furthest I've seen is 280 miles, however you've always got petrol to fall back on, just dilutes the economy a bit! Range Rover-less at the moment - Pining!
Post #86831 11th Oct 2011 9:54pm
Go with the LPG route but maybe get the toroidal tank and an underslung one on the passenger side a well if they will let you.
LPG tax worries have been around for years but it just goes up at the same rate as petrol and derv anyway.
Also take the chance to Decat it while your at it and enjoy the extra noise Very Happy
If you want to go for the TDV8 then maybe wait a bit longer and get the 4.4 Smile
Im guessing your fuel card is Business but you can get cheaper fuel using personal fuel cards these days too and with an SC you probably use the the 500litres pcm minimum requirement Smile
Post #86853 12th Oct 2011 7:08am
Also been weighing up the options al , but don't think i could go the LPG route having previously had the 3,0 FFRR and now the SC , i think i would like to try the 3.6 TDV8 rather than the 4.4's ……….
Saying that if the right 5.0 Litre FFRR came along …. Whistle Laughing Laughing
Post #86860 12th Oct 2011 7:22am
Having read a copy of the new MOT Inspection Manual for MOT's as from 1 Jan 2012 I would advise against cat removal on any spark ignition engine ie petrol, lpg etc as a cat not in place on a vehicle that was fitted with one at manufacture is a "fail".
As far as I can tell cat removal on diesels will still be ok.
Post #86862 12th Oct 2011 7:35am
IIRC LPG is exempt from this as part of the LPG encouragement as it allows the vehicle to recover the power that it loses from having LPG fitted Smile
Post #86867 12th Oct 2011 7:56am
There is no exemption for anything to do with LPG in the existing Mot Testers Manual, it actually states "This inspection applies to all petrol, diesel and gas powered vehicles".
Equally in the new Inspection Manual no cat on spark ignition engines, fail.
Simples Smile
Post #86868 12th Oct 2011 8:07am
