Home > In Car Electronics (L322) > DAB tuner
DAB tuner
As most folks know on here, adding an OEM DAB tuner to the FFRR is not an easy job, so this is my solution :-
 Got - 2017 SDV8 Autobiography in Loire Blue
Post #86315 9th Oct 2011 9:23pm
more info please alan.. ... - .- -.
Post #86346 10th Oct 2011 7:32am
What do you need to know Stan? Got - 2017 SDV8 Autobiography in Loire Blue
Post #86348 10th Oct 2011 7:53am
make ,price, easy/how to fit? ,dab reception.. Wink ... - .- -.
Post #86350 10th Oct 2011 7:57am
This is the baby - http://www.dabonwheels.co.uk/Acoustic_Solu...radio.html
There's an RJ45 cable that connects the base unit that's in the boot to the display unit, which I screwed into the centre console which is probably the hardest bit to route through,
The unit can either provide output via an Aux out, but I used the FM option and use a preset on the head unit.
I used a small T-piece to take a feed from the radio antenna and the reception is good enough for most areas!
Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #86351 10th Oct 2011 8:03am
thanks alan, does it route the sound through the RR system or is it standalone..
edit, just read the instructions... Thumbs Up ... - .- -.
Post #86352 10th Oct 2011 8:07am
It goes through the RR sound system Stan. It has no audio capability other than to output via the line out or a chosen FM frequency. Got - 2017 SDV8 Autobiography in Loire Blue
Post #86354 10th Oct 2011 8:09am
looks like a pretty good system...cheers for the info Thumbs Up .. ... - .- -.
Post #86355 10th Oct 2011 8:11am
Well, like you, I hate things that look non-integrated, and this was as close as I could get.
If you decide to go down this route, I'm happy to help out with any more detailed info. Getting hold of the T-piece and antenna cable was a bit of a job, but since I had done this before on my last BMW, I had an idea of who sold them. Got - 2017 SDV8 Autobiography in Loire Blue
Post #86357 10th Oct 2011 8:15am
i've been yearning for dab and i wanted to get a proper landrover dab unit ,but these are like rocking horse stuff ..without the antenna this seems quite reasonably priced. ... - .- -.
Post #86379 10th Oct 2011 10:07am
Indeed, it's probably the most cost effective way to do it.
Apart from which I'm assured that >MY07 it's not an easy task even if you have the DAB module as the touch screen doesn't ever show the DAB as a source even after it's fitted and coded.
When I had my E60 BMW is retro-fitted an OEM DAB unit despite being told by BMW that it wasn't possible, but Autologic spotted it and all was well. In that case I used a feed from the TV antenna which is in the rear window.
I do believe reception is better on the RR than on the BMW Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #86381 10th Oct 2011 10:13am
