Home > Technical (L322) > Rear brakes won't bleed???
E18RLY
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
I have a 52 plate range rover and had a leak on a brake line after topping the fluid up twice in a week I got a mobile mechanic out. He replaced a pipe and tryed to bleed brakes ( apparently they bleed there selves) after it didn't he tried doin it normally and still wouldn't he plugged his machine in and tried again still nothing. Front brakes work the back Dosent please help ????
Post #85254 4th Oct 2011 1:59pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Re: Rear brakes won't bleed???
Get a better mechanic! I don't think there is anything too tricky about bleeding the brakes on a FFRR. If you are in the midlands try Jason - 07903 077948 - He's done a lot of work for me over the last 4 years and is excellent.
Post #85412 5th Oct 2011 10:20am
mzplcg
Erm South Shields is Tyneside, not midlands.
Anyway, take it somewhere else. Brakes are kind of essential and not worth taking risks with.
Dom
Post #85419 5th Oct 2011 12:17pm
daveo
where was the leak..have your rear disk's been working ie. are they shinny... V8 facelift Range Rover Autobiography 22" wheels.
Post #85494 5th Oct 2011 6:17pm
E18RLY
The leak was on pipe going down passenger side to rear brake. Drivers side rear is bled but passenger won't. All are shiney except passenger rear ??
Post #86236 9th Oct 2011 4:05pm
