![]() | Home > Technical (L322) > paddling pool around the compressor in boot !!!!! Help !! :( |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
Maybe this Forum is jinxed... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
i'd investigate the possibility of an open tailgate or the range parked in a different position maybe.. ... - .- -.
Right, thanks.
you cant make any certain decisions until you clear the fault i reckon..investing in the RAC or IIDTool would be a sound idea cos you'll never know when you need one.. ... - .- -.
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 ![]() ![]() ![]() |
its difficult to decide which is the best tool tbh, both have their strengths and weaknesses..have a read of the threads concerning these two.. ... - .- -.
If I'm honest I'm more inclined towards the rsw all comms tool however I'm not sure if it can only be used with one rr or as many as u need.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
The RAC is a good tool. It's the cheapest of the lot but you need a laptop to use it so not as mobile as the IIDT. The RAC will do any RR from 2002>2004. (pre facelift). If you have a TD6 it can't currently read the engine codes but storey is working in it I think. Have a read on here as there are a few threads about these. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
I don't mind using my laptop. I'd probably prefer it. I have a 2004 most system I imagine as I have touch screen sat nav 54 plate.
Stoich Member Since: 21 Dec 2009 Location: Stornoway Posts: 36 ![]() ![]() |
Here's my tupence worth on this problem for what it's worth.
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
If I am not mistaken, with the spare wheel removed you will see a pipe coming from the compressor into what looks like a round black sponge, I believe this is the filter. On mine looking into the boot from the rear its on the right near the back. Reformed |
Hi All |
Try connecting with the ignition on but not started (so all the ignition lights are on) Reformed |
