Home > Maintenance & Mods (L322) > 2003 to 2009 facelift
W88DY M
United Kingdom 2003 Range Rover Vogue Td6 Oslo Blue
hi all
just getting parts together for a 2009 facelift and would
like to know if i can use my old bumper bar
or do i need a new one. And apart from HEADLIGHTS,BUMPER, GRILL
is ther anything else i need
thanks mark.. Thumbs Up Thumbs Up Bow down
Post #85903 7th Oct 2011 8:25pm
bozmandb9
A degree in electronics, or a very good wiring conversion kit/ fix, to resolve the issues with wiring the facelift lights.
I assume you're talking about the 2010 facelift, the headlights aren't a straightforward fit in terms of wiring, then you might want to update grills and rear lights.
Plenty of info and examples if you search on 2010 conversion. Thumbs Up Range Rover-less at the moment - Pining!
Post #85936 7th Oct 2011 10:07pm
dont think you can use the old bumper bar, needs a facelift one..all the conversions i've seen on ebay always have one included making me think you have to have it to mount the new bumper... ... - .- -.
Post #85981 8th Oct 2011 9:17am
W88DY M
hi
no its the 2006 to 2009 facelift that i am doing
I have the new rear lights and side vent just need to do the conversion now
any help on doing this would be helpful
thanks Bow down Thumbs Up Thumbs Up
Post #85983 8th Oct 2011 9:19am
your title says 2003 to 2009 ? ... - .- -.
Post #85984 8th Oct 2011 9:21am
W88DY M
Thanks Scarey Thumbs Up
looks like i need a bumper bar then
ill put some pics on when i am doing it
Mr. Green
Post #85986 8th Oct 2011 9:23am
you fitting the new led rear lights? ... - .- -.
Post #85987 8th Oct 2011 9:23am
W88DY M
sorry my ffrr is a 2003 and i am doing a 2006 to 2009 facelife Embarassed
Post #85988 8th Oct 2011 9:24am
W88DY M
no i have the sc ones in
Post #85990 8th Oct 2011 9:25am
ok and good luck mate. Thumbs Up ... - .- -.
Post #85991 8th Oct 2011 9:26am
W88DY M
Thumbs Up Thumbs Up
Post #85993 8th Oct 2011 9:27am
You will need 2 headlamps (the more basic the easier the wiring)
Bumper
Bumper reinforcer
Plastic front support panel
front wheelarch liners
2 wing corner bumper support brackets
foglamps + wiring
Headlamp wash system (new pump and pipework from Land Rover) will be MOT requirement in 2012!
Strip off the existing front end and bin it. Cut off the front wing lips and weld or bond the inner and outers back together. Modify lower wing to bumper brackets to fit. Modify wiring, Bolt on all new parts. Around 10hrs to do this job for an experienced converter... Allow a couple of days if its your first time...
Its a lot of work but well worth the effort...
Speak to Simon at powerfulluk.com he sells plug and play looms for the headlights...
Craig Thumbs Up
Post #85998 8th Oct 2011 9:38am
bozmandb9
If you can get them, I'd highly recommend the bi xenon adaptive lights, I have them on my 2006 MY Supercharged, first time I've had working adaptive lights, and they are fantastic! Thumbs Up Range Rover-less at the moment - Pining!
Post #86147 9th Oct 2011 7:14am
David, they cannot be retro fitted my friend... Need ECU's connected to gearbox, air suspension, speedo head and many many more to take all of the relevant data to the lamps...
Have you noticed yet, not only do yours move with the steering but also up and down with acceleration and breaking...
Craig Thumbs Up
Post #86163 9th Oct 2011 9:17am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Cam-Tech-Craig wrote:
..SNIPHave you noticed yet, not only do yours move with the steering but also up and down with acceleration and breaking.../SNIP
WOW, >2 years on and I didn't notice, thanks Craig! Thumbs Up
Post #86183 9th Oct 2011 10:02am
