Home > General > Help Please - Won't Start, Also "Transmission fault&quo
rads
2005 Range Rover Vogue SE Supercharged Tonga Green
Morning all.
Was really cross last night - noticed the approach lights in the mirrors are not working. Checked the bulbs, checked the fuses then retired defeated.
This morning the bloody thing wont start!
Puts the approach light problem into perspective.
Unlocks normally, doesn't feel like a weak battery if you know what I mean, but nothing from the starter.
After turning the key to the start position, I get two error messages, "Transmission Fault Limited Gears Only" and "HDC fault system not available".
I think these messages can be triggered by a weak battery but I did put a very heavy duty jump pack onto the jump posts under the bonnet and the car still did not turn over, and the messages stayed.
Really looking for some suggestions as to next steps.
Is it worth throwing a battery at it? Would have thought the jump pack would have made a difference if that was the problem.
All and any thoughts appreciated.
David
2005 4.2 SC
Post #85535 6th Oct 2011 9:37am
The "Transmission Fault Limited Gears Only" and "HDC fault system not available" could be related to a power loss and require the steering wheel turned left and right once the vehicle is started to clear. Not starting could be the inhibitor switch on the gearbox not contacting properly, use search on the forum for tips from Gazellio to lubricate the gear linkage
Post #85539 6th Oct 2011 10:06am
i would say its the battery ... ... - .- -.
Post #85540 6th Oct 2011 10:19am
rads
Thanks.
Did try cycling the gear selector back and forward.
Light on the selector correctly indicates gear position, as does message centre. Presumably if the selector is correctly indicating P or N then this should discount a stuck linkage?
David
Post #85542 6th Oct 2011 10:20am
rads
Replying to my own, bad form!
Just spoke to Gazellio, who advised check of the gear linkage as suggested by 47p2. Apparently indicators on the gear lever only show where the lever is, not where the gearbox selector has moved to.
David
Post #85553 6th Oct 2011 11:28am
rads
I am an official idiot.
Stuck a fuse back in the wrong slot last night.
The one that does gearbox and diagnostics.....
Embarassed
David
Post #85666 6th Oct 2011 6:58pm
Rolling with laughter Rolling with laughter
Post #85695 6th Oct 2011 9:13pm
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
That's got to be a big relief!
Just need to sort out the approach lights now! Bet you're not so worried about that now though! 2012 SDV8 Vogue SE
Post #85696 6th Oct 2011 9:14pm
