Home > For Sale & Wanted > FS: 2x remote fob internals
Mikey
As per title, 2 brand new key fob internal circuit boards
Never used, or coded to a car, and not available seperatly from a new key
£20 each inc post
Post #84958 2nd Oct 2011 7:22am
Which model / generation? I need for '02/03...
and what would I do with them? Can I buy a new key fob and install, if so can you specify? Do I need LR to programme? .
Post #84975 2nd Oct 2011 10:07am
LR don't need to programme a 2002/3 key fob, there is a write up somewhere on the site and also should be in Wiki about how to do it
Post #84980 2nd Oct 2011 10:32am
Mikey
They are for the early type key 02-06MY, i.e. not the flip out kind
Post #85014 2nd Oct 2011 4:46pm
So, I buy one of these (or similar):
and then I buy one of your internal circuit boards
put the circuit board in the fob, get the blade cut to match my existing key....then what? Do this?
Quote:
Programming a Key
1) Get in and close all doors. Turn ignition on and off quickly and remove the key (all within about 5 seconds).
2) Within 30 seconds of turning the ignition off, while holding down the "unlock" button, press the "lock" button three times. Release the "unlock" button. (You may or may not get the confirmation from the door locks.) Holding the key at your head level provides best results as the key sensor is in the side window pillar.
3) Repeat for each key you want to initialize within 30 seconds after the last one you initialized (if you have more).
4) Right after doing the last key, quickly put the key back in the ignition and turn it on/off again to finalize.
But I need a transponder too? .
Post #85074 2nd Oct 2011 10:03pm
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
PM sent.
Cheers - Gav
Post #85103 3rd Oct 2011 1:41am
Mikey
Quote:
Programming a Key
That is only to re-sync the remote locking.
If you bought a brand new key, it would still require programming to the car, but the transponder is in the key casing, and not the circuit boards
If you had the original key, you could swap over the transponder chips, thus not requiring any programming, only a re-sync as posted above
HTH Thumbs Up
Post #85188 3rd Oct 2011 4:56pm
Mikey
Both prov. sold, pending payment
Post #85217 4th Oct 2011 5:32am
