Home > Dealership & Service Feedback > FFRR diagnostics in Glasgow |
Had the dreaded Air Suspension Inacvtive, HDC Inactive along with ABS lamp, DSC lamp, and Brake Warning lamp all illuminated on the FFRR. I took the vehicle to an indie who did a reset and I was told it was 'sorted' only for the dashboard to light up a couple of miles down the road.
30th Sep 2011 8:45pm |
Speaking with them yesterday they told me they have been on a number of LR courses recently, and had new software, what software I'm unsure but always worth asking. I certainly found them to be more than helpful |
1st Oct 2011 12:02pm |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 |
What did they tell you about the fault? I have the same problem at the moment - always comes on when on the motorway after a couple of minutes. I can reset myself and having read the fault codes I think in my case the steering angle sensor may be playing up, but I'm interested to see if the cause of mine could be the the same as yours and therefore what I would need to investigate to determine whether that is the case. |
1st Oct 2011 8:15pm |
Bit of a long one this.............
2nd Oct 2011 3:46am |
Thanks for the long explanation! I'd realized the systems are all linked having read the descriptions in Rave and various other postings around the net. I have a CAN Bus fault showing and (last time I looked at least) a steering angle sensor issue, but can't remember the exact fault description for the latter. It happened again yesterday so can re-download the faults with my RAC. My steering wheel is slightly off by 2-3 degrees but I've no reason to suspect there's any alignment issues because the tyres are wearing evenly. I think it is more likely that as the tracking has been adjusted over the years the steering wheel has wandered from the straight ahead position slightly. My theory with my car is as follows, since it only seems to happen when on the motorway: After the recognised time period of straight ahead running > 50mph (or whatever the speed is) the system lowers to motorway height. However, a fault on the steering angle sensor is preventing the system getting a clean reading, so it keeps trying to reduce the height. After a set period of time (or perhaps number of attempts to lower), the attempts are discontinued and a fault warning is triggered. The link between the angle sensor and the suspension is that the suspension won't change height whilst cornering, but if the air suspension ECU can't recognise the position of the steering wheel due to a sensor fault then it will eventually report a fault. Sadly, replacing the steering angle sensor requires a Testbook recoding, so although I could do it myself I'd still need to visit a dealer. This makes me less likely to give it a try to see if that really is the problem. It's all just theory at the moment ! |
2nd Oct 2011 8:43am |
Can you not take it to an indie who has the equipment to read the angles of the steering sensor, they can be re-calibrated but only within certain parameters. I was told if the steering wheel had been removed and not put back on in the same position it can throw the sensor out, also a faulty rotary coupler behind the steering wheel can cause the steering angle fault, there are so many things that can be the cause. The can bus fault could be relating to almost anything and possibly nothing to do with your fault. Mine was showing a can bus fault but was nothing to do with the problem. Your problem sounds similar to what I had, I thought mine was speed related and have read that the ABS sensors sometimes send false readings to the ECU when travelling but show no faults when tested, something else to look into. The sensors are not expensive, around £20 a corner.
2nd Oct 2011 9:33am |
The ABS sensors can't be read by RAC unfortunately. Only the fault codes from the ABS module - there is a new error stored there referring to 'EBV' but I don't recall the full error message. Will have to fire up the lappy and read it again. The other error is a steering angle plausibility error. As this one is the result of a plausibility check I'm more convinced it's related to the steering angle sensor than anything else. The other systems (ABS, Air Susp etc) all require a steering angle feed so if this sensor goes it'll definitely cause issues. I'd say the steering is no more than one spline out. I have had the wheel off to fit the new spoke covers but I did that a long time ago and I put it back exactly as it was having marked it for alignment before removing it. I see where the theory comes from - if the car thinks it is turning for a long time then this would probably generate a plausibility error. However, the steering has been left/right calibrated and I don't think the physical position of the wheel makes any difference if the car tracks straight and true without touching the steering wheel. It could just need a deeper calibration carrying out, but it's odd that it only does it on the motorway after 5 minutes or so of high speed driving. I could indeed take it to an indy, but I'm a DIY sort of guy and I hate having to admit defeat and hand over my hard-earned to someone else! |
2nd Oct 2011 5:10pm |
