Home > In Car Electronics (L322) > Bluetooth Module - 2005
redshovel
United Kingdom 2010 Range Rover Autobiography Black TDV8 Barolo Black
I know this is most likely buried here somewhere but can someone point me in the direction of upgrading the bluetooth module in an 2005 (06 Model Type) FFRR.
My aim is to use the iPhone 4 with having to input the 2121 code at each reconnect.
Post #84383 28th Sep 2011 11:37am
rads
2005 Range Rover Vogue SE Supercharged Tonga Green
Wiggs is your man.
http://wiggy.getmyip.com/ffrr/help.HTML
£60 and half an hour is all you need.
David
Post #84391 28th Sep 2011 12:29pm
HUGI
Switzerland 2006 Range Rover Vogue Supercharged Java Black
yeah wigg is the right person,but I would advise you to get a Module from the D4/2010 RR from him.
I paid him 120£ for it and it is worth every penny,it works great and with all new phones.
So it depends on your budget but I would say get the new module Wink
Post #84413 28th Sep 2011 1:44pm
rads
Interesting.
Does the new module allow multiple numbers for one contact?
That is about the only problem I have with mine now, pairs beautifully with an iphone, phone book transfer, but only 1 number per contact.
David
Post #84418 28th Sep 2011 1:56pm
redshovel
Thanks for the link - thats exactly the info I needed.
Post #84431 28th Sep 2011 2:50pm
HUGI
@ david
I will check it tomorrow for you
Post #84459 28th Sep 2011 4:44pm
killatomato
United Kingdom 2005 Range Rover Vogue Td6 Java Black
Wiggs, pm'ed you
Post #85012 2nd Oct 2011 4:22pm
HUGI
sry,forgot to answer.
It does display several numbers for one contact.
Some contacts it even says that it is the number from the iphone,home,business or whatever
Post #85174 3rd Oct 2011 3:06pm
stu
can someone please advise me of the benefits of upgrading to a newer module please?? Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #85331 4th Oct 2011 7:34pm
wiggs
If you mean the newer 2010 modules
Holds 1000 contacts instead of 300
Shows service provider
Shows signal strength
Allows multiple numbers for one name
Post #85371 4th Oct 2011 10:26pm
stu
so if you upgrade to a newer module it will look like what's in the picture from your link at the top of this post??
if that is correct, mine looks like that already!!! what is the part number of one of the newer ones? i will have to have a look at my module when i get two mins. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #85378 5th Oct 2011 4:27am
