![]() | Home > Technical (L322) > squeaky belt noise on startup |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
My SC suffered from a squeak on startup, which was rectified under warranty by replacing the main drive belt pulley.
Are you sure its the belt and not the tensioner? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
what range have you got barrieeld, you need to update your car profile.. |
barrieeld Member Since: 07 Dec 2010 Location: Scotland Posts: 260 ![]() |
Hi I've got a supercharged if that helps. My cars a 2006 so it'll be out of warranty.
FYI my SC is also a 2006, the warranty is the approved used warrenty that comes with a main dealer supplied car.
Hi I bought my vehicle privately although it's been looked after from a maim dealer from new it won't have any warranty I don't think? Any idea the cost of the parts? |
Its a common issue but the squeak normally disappears after warm up. Not sure if leaving it will lead to mechanical failure? |
Yeh that's right after warmup the engine squeak disappears. |
The paperwork shows less than £50 all in for the parts, but that may be discounted as the LR warranty picked up the bill. ![]() Gone - Range Rover Supercharged 2006 ![]() |
SharpV8 Member Since: 12 Sep 2011 Location: Northumberland Posts: 8 ![]() ![]() |
Had exactly the same problem on my 2006 SC, although in my case they diagnosed a faulty belt which was replaced (not under the LR warranty sadly)... I thought it would be the pulley and was sceptical a new belt would fix it, but the noise has certainly gone - along with a clutch of notes from my wallet |
