![]() | Home > Maintenance & Mods (L322) > Howto: TD6 Transfer Box Oil Change |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
New photo tutorial on changing the oil on your TD6 transfer box |
What was the oil you removed like Joe, mine was way beyond its sell by date |
A bit thin, very black, not too gritty and no swarf. I had a new gearbox @ 30,000 miles ago, and don't know if this oil got changed then, but given the difference between the old and the new oil, I was glad I changed it. . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
On a note would it be worth having the car on an incilne to help drain more of the old bad fluid out and then if possible allowing the car to roll back onto flat ground to fill up??
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35656 ![]() ![]() |
i've taken the liberty to wiki this joe....good job as always. |
DaveAngel Member Since: 15 Aug 2011 Location: Cowplain, UK Posts: 205 ![]() ![]() |
Great post Joe,
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
After you did the oil change did you operate the hi / lo range selecter as the bit of kit in the box that changes from hi / lo requires hyd oil to change selection if not when you operate it it will suck oil up to fill the pump and leave your level in the box low please check level after operating the hi / lo selection |
This is the transfer case (box) oil change, not the main gearbox, so just a 1 litre bottle of "unique" oil for @ £12, and about half an hours work. . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
I would have done the hi/lo change about, but this is the part of my transmission that doesn't work!. If I put into low range I get the TFP message on the dash, and the ![]() Wasn't aware the hi/lo shift required the oil other than for lubrication, if you check out RRPhil's video on a cutaway gearbox, it seems it is a very straightforward mechanical movement. I saw your other post about this and was a little unsure about the hydraulic requirements? . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
