![]() | Home > General > 100k 05 vogue bad idea at milage/age? |
Mines on 127k now and fingers crossed wil be ok. Depends on the life its had really. If its been towing and been pushed hard then the box and diff's will have had a harder life i guess.
barrieeld Member Since: 07 Dec 2010 Location: Scotland Posts: 260 ![]() |
just bought a 2006 vehicle with 140k on the clock goes like a train! The reason i bought it was it had full dealer service history from new and wanted for nothing with 1 owner. Like any car you can tell if its been looked after and 9/10 if it has regardless of mileage it should serve you well.
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Why ![]() ![]() Gone - Range Rover Supercharged 2006 ![]() |
because at 60k most vehicles are just breaking in and big undesirables like gearbox air suspension etc if there going to go will go around 60-80k mark. my opinion anyway.... |
Pauld Member Since: 15 Mar 2010 Location: Sheffield Posts: 199 ![]() ![]() ![]() |
If they go at 60-80k, surely they will go again at 120 -140k.....
i agree my point really was at 60-80k a cars true characteristics wont be shown as its just being run in. |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1022 ![]() |
I think a 100k Vogue is absolutely no problem. To be honest I think mileage is really pretty irrelevant on these cars. My previous S/C had 40k more miles than my current one, but if you had to judge them on condition you'd place them the other way round (not that there's anything wrong with my current one, it's just that the previous one wore the miles really well).
baba Member Since: 24 Aug 2011 Location: ayrshire Posts: 29 ![]() |
So the facelifts had the diff problem sorted from the factory?Handy to know. Yes i wont get one thats showed obvious signs of towing/hard life. And il change all oils etc for piece of mind.So a 100k mile vogue if looked after before should be no more of a risk than a 40k mile one thats hard a sore time? Any test i can do whilst viewing to make sure all is well? |
Give us a clue on budget, engine preference etc? Generally raise and lower suspension (doors must be closed), should go up and down pretty quickly with no errors. Check all electrical gadgets, extended test drive if possible, try moving from standard to low ratio (on a very quiet road or in a car park). Usual checks under the bonnet for fluid levels /condition, look for oil leaks, leave to idle then check temp. In an ideal world you would put it up on a ramp and check underneath for corrosion, which it'll probably have, but should all be superficial/ surface corrosion. If none present then it's a really good sign that it's had an enthusiast owners who's treated and waxoyled it! Range Rover-less at the moment - Pining! |
Excellent advice ![]() |
I just wish I followed my own advice! ![]() |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
It is good advice, however a note on testing the suspension: It should go up and down quickly but when testing it you can easily deplete the air reservoir meaning it has to rely on the compressor only. As a result it will appear to be initially responsive then will go very slow. Just need to be aware of that. If you open the tailgate and lift the spare wheel cover you can check to see how long the compressor runs for. It's also fairly easy to get underneath if you put it in full height mode and (don't have a beer belly!). Leave a door open while you're under there. |
I really don't get the hang ups that people seem to have with mileage. It's largely irrelevant nowadays especially on diesels. Problems on FFR are well documented. Check for these and you're on the way to a good car.
Milage has never put me off any other car before i buy on codition but some people on here have made out there prone to breaking after 100k.
