![]() | Home > General > LPG Recormendation in Croydon/ Surrey area |
Chap called Bernard at TMC Gaspower. Near Biggin Hill. Done a few of mine and all were exceptionally well done. |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 ![]() |
I used Euro LPG in Wembley area to convert my Supercharged L322. I was very happy with the installation, I'd highly recommend them, and BRC kit. Personally I went for a filler under the bumper, which was very discreet.
rads Member Since: 04 Sep 2011 Location: Herts Posts: 157 ![]() ![]() |
Had an under bumper filler on my P38, and would probably do the same on my SC, if only so the car can be filled from either side. Garage LPG fill hoses seem to be getting shorter, no chance of stretching one to the "wrong" side of the car.
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 ![]() ![]() |
Cheers for the input
92/95 litre four vented tank, probably stake, in spare wheel well. Compressor will need to be moved to behind the tank, or to the right hand side compartment of the boot.
Tank size = the largest which will fit, usually the 95 litre in the spare wheel well. Another trick is to specify a 4-hole tank as these can have the fill stop removed/adjusted |
thanks for the info, the I know where Euro LPG is, so thats puker |
Looking into what systems they install and I'm seeing alot of BRC kits r these good??
I found BRC extremely good, and I read a lot of very good feedback about them when I was doing my research. I think the Lovata kits are perfectly good for the 4.4 M62 though, and cost less.
cheers dude, ive just found this pic on here and wanna get this done |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6743 ![]() ![]() ![]() |
That's neat! |
Ok, what system is the best been offered a BRC system
Prins is widely accepted as being technically the best. Rather pricey too. Other good ones are Tartarini, Vogels and Landi Renzo. I've had all of these and they all worked very well.
cheers dude, ive heard of PRINS before as well as STAG
