Home > Site News & Feedback > wiki
wiki
i've spent some time sorting out the wiki so its easier to use and find stuff...have a look and let me know if there are any problems or bits that need tweaking..
stan ... - .- -.
Post #82304 19th Sep 2011 8:03am
Thumbs Up Looking great on the wiki Thumbs Up .
Post #82311 19th Sep 2011 8:55am
Thumbs Up ... - .- -.
Post #82312 19th Sep 2011 8:56am
Much much better.... Thumbs Up
I noticed the Key Fob Programming routine (Key in turn turn ign. onn/off quickly Hold Unlock while pressing lock three times then release unlock heat unlock/sound then other key then key in on/off etc) is not there?
Post #82313 19th Sep 2011 8:59am
cant remember seeing that key fob how to , do you want to add it into the wiki gary? ... - .- -.
Post #82316 19th Sep 2011 9:08am
NEW KEY FOB PROGRAMMING
Going out but:
Hold Unlock while pressing lock three times then release unlock button
Hear unlock/sound
Then within a few seconds repeat with other key
Listen for unlock/sound
Then within a few seconds key in ign. and on/off quickly
Job done
Post #82321 19th Sep 2011 9:19am
found this by dan,
Initialization Procedure
*Ensure the vehicle is unlocked and the driver and front passenger doors are closed.
*Install a key/remote handset in the ignition switch, then turn the ignition switch to position I and back to position 0 in less than 5 seconds to put the GEM into the initialization mode. Continue the procedure within 30 seconds of turning the ignition switch to position 0.
*Remove the key/remote handset from the ignition switch.
*Press and hold the unlock button for a maximum of 15 seconds. During this time, momentarily press the lock button three times within 10 seconds.
*Release both buttons.
*Successful initialization is indicated by the GEM locking then unlocking the vehicle. If this does not occur, repeat step D.
*Repeat steps D. and E. with all other remote handsets belonging to the vehicle (4 maximum). Begin the
initialization of each remote handset within 30 seconds of completing the previous initialization, or the GEM will
drop out of the initialization mode and the complete procedure will have to be started again.
is this the same thing? ... - .- -.
Post #82323 19th Sep 2011 9:21am
Perfect but it need a finanal section:
YOU need to put the key back in the ignition and turn on/off to finish the procedure!
*When all handsets reprogrammed quickly put key back in ignition switch and turn to 1 and back to 0 to finalise procedure.
Gary
Post #82326 19th Sep 2011 9:24am
gary, i cant remember seeing the 'lubricating gear linkage' tip that you posted being on the wiki ,so maybe include that when you do the key fob tip... ... - .- -.
Post #82433 19th Sep 2011 3:27pm
It is there Scarey:
http://www.fullfatrr.com/wiki/TDV8_Gearbox...s_of_drive
Maybe you want to move it forward to its own title....
Post #82555 19th Sep 2011 11:11pm
Thumbs Up you're right, hidden in the common problems bit.... ... - .- -.
Post #82569 20th Sep 2011 6:59am
