Home > Technical (L322) > Compressor removal
algt2
Scotland 2006 Range Rover Vogue 4.4 V8 Zermatt Silver
Compressor removal
Does anyone know if it’s possible to remove the compressor mounted under the spare wheel but still be able to use the car, I know that the suspension will be inactive but other than that will it give me any other issues???? also has anyone found a service kit for the compressor??? I’ve googled the Wabco part no. but can’t find anything??
Post #82017 17th Sep 2011 3:43pm
bozmandb9
I would say most certainly not, it will not be usable in any meaningful sense. Loss of suspension will take with it most other dynamic safety systems, make it ride like a pig. You could limp along for a little while, but certainly not use it as normal! Maybe somebody will have a compressor you can borrow or something! Range Rover-less at the moment - Pining!
Post #82018 17th Sep 2011 3:49pm
with no air in the system , the range will go onto its bump stops and you wont be able to drive it like that.. ... - .- -.
Post #82021 17th Sep 2011 3:55pm
algt2
Just tried it out, the system appears to retain the air already in the system it just doesn't replenish any (obviously) so as long as you're not asking for up and down adjustments it could be ok? I’m not going to risk it though, I thought I could take the compressor out and service it but it has now miraculously repaired it’s self. was getting a “suspension fault, normal height only” fault!
Post #82031 17th Sep 2011 4:34pm
you obviously scared it into working... Thumbs Up ... - .- -.
Post #82033 17th Sep 2011 4:37pm
algt2
Rolling with laughter it’s going to wait and lull me into a false sense of security then fail spectacularly in a cloud of nuts and bolts!
Post #82034 17th Sep 2011 4:40pm
