Home > Technical (L322) > Squeaking rear suspension |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
My FFRR has developed a loud squeak which is coming from the rear Suspension:(
15th Sep 2011 11:12pm |
This has been covered a bazillion times before. The rubber bushes are worn and need replacing. They wont be covered under warranty I'm afraid as they are "worn"
15th Sep 2011 11:21pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16207 |
I had three changed for a customer at Stratstones and they charged me £360 trade... eeeek! |
16th Sep 2011 7:54am |
Hi Guys,
21st Sep 2011 8:42pm |
Number 16 in the picture below. Easy enough when the cable has been removed. You could pull the cable to one side of the bracket number 17 and wrap lots of electrical tape around it for the time being
21st Sep 2011 8:50pm |
The tape idea sounds like a good suggestion, although as my handbrake is rubbish it's probably worth changing the cable anyway.
21st Sep 2011 9:00pm |
The cables are pretty robust and the self adjuster at the bottom of the lever will take up any slack unless the cable is stretched to the extremities of its capabilities.
21st Sep 2011 9:09pm |
I've already adjusted the handbrake adjuster as far as it will go, so I guess I need new shoes and a new cable?
21st Sep 2011 9:11pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2929 |
I heard a creaking sound when I was towing the caravan home yesterday. Didn't do it on the way to Wales, but it drove me mad on the way home!
25th Sep 2011 5:41pm |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
Mine does this, and by pressing the + button on the right side of the steering wheel I managed to fix it from inside the car@
25th Sep 2011 6:41pm |
