Home > Technical (L322) > Help Needed...Multiple Warning Lights |
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 |
i had a similar issue it could be your battery |
12th Sep 2011 6:47pm |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 |
I'd second that and change your battery or at the very least get it properly tested.......it's a lot cheaper. 5.0 supercharged autobiography
12th Sep 2011 7:17pm |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
I suspect the gearbox will turn out to be unrelated, I would get your gearbox oil changed immediately if I was you! Hope it is a battery issue with the warning lights! Range Rover-less at the moment - Pining! |
12th Sep 2011 8:08pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
i would be asking for the money credit back for the abs for a start.. i will say battery as well V8 facelift Range Rover Autobiography 22" wheels.
12th Sep 2011 10:04pm |
mrbon007 Member Since: 19 Apr 2011 Location: London Posts: 11 |
Thanks for the replies!
13th Sep 2011 11:09am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35284 |
go for a 110amp 920 cca bosch/varta battery from europarts or an online supplier.... |
13th Sep 2011 11:30am |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1511 |
+1 |
13th Sep 2011 12:32pm |
COOL!
13th Sep 2011 1:53pm |
swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69 |
It doesn't sound right that you need a new ABS ECU, I don't see why it should fail.
13th Sep 2011 2:00pm |
Hi, yes it is a specialist with proper RR diagnostic equipment and it seemed to pinpoint a specific sensor on a specific wheel, which was then replaced. When the lights came on again they claimed they could then not reset the lights, whereas previously they were able to. Another thing I have noticed is that when these lights are on the sat nav stops working?! By that I mean the map freezes your position wherever you were when the lights came on?! |
13th Sep 2011 8:46pm |
Oh right, I never needed my lights reseting because every time the ignition was switched off it reset it's self again, until the next time I was doing a motorway drive.
14th Sep 2011 5:56am |
UPDATE...
4th Oct 2011 8:34pm |
Could be numerous things causing the light to show as the Air Suspension, HDC, Steering Angle Sensor, Speed Sensor and possibly a few more sensors are all interlinked. You need to find an electrician who knows what he's doing |
4th Oct 2011 9:02pm |
What was the outcome of the battery test? Just because it passes a basic test, doesn't mean it's not the cause of your problems! Could be a red herring, but still something worth considering, how old is the battery? Range Rover-less at the moment - Pining! |
4th Oct 2011 9:06pm |
