Home > For Sale & Wanted > Wanted towbar thingy
Page 3 of 3 <123
You should try some PlusGas penetrating oil instead of WD 40.
WD 40 isn't a penetrating oil it's a water dispersant whatever it says on the can.
PlusGas is much more effective at freeing rusty bits.
If you ever do get it out just coat the thing with black grease before you put it back in, won't stick then.
Post #80884 13th Sep 2011 1:43pm
supershuttle wrote:
'Fraid so, well insofar as it certainly went in but it's very reluctant to come out.
very strange.....try a bottle jack on its side ..
Post #80892 13th Sep 2011 2:18pm
supershuttle
I guess the first owner of the car fitted it in 2007 and it's never been out since, I've only had the car months and off and on I've been trying to remove it since I got it.
I will try a different penetrating oil - thanks for that - and of course a bigger hammer. I have actually, in a rare act of pragmatism, just bought a new bike carrier (delivered this morning) that clamps to the tow ball (the LR ones seemed too pricey) which obviously makes it at least useful to me to have it on. Just to be crystal clear though I am in no way giving up - I will keep trying to get it off because it should come off, it will Censored come off and it wil look better off Very Happy
I refuse to be beaten Shocked
and I am sorry if I accidentally hijacked this thread - again Whistle Geoff
Post #80896 13th Sep 2011 2:42pm
supershuttle
Thanks Stan but I bought a 4T bottle jack specially to try that - didn't work but it's better than the dodgy scissor jack that comes with the car so nothing lost Very Happy Geoff
Post #80897 13th Sep 2011 2:45pm
Might be worth taking the towbar off the car, you could then stand it on it's sides and pour penetrating oil in from both ends. Would also allow you to knock it out from the "far end".
Post #80902 13th Sep 2011 3:00pm
I tried a 12 tonne bottle jack on its side, and all that done was to put a strain on the hitch plate. It bothered me too supershuttle, more so because when I reversed into my driveway the hitch would sometimes bottom out on the pavement.
Easier to remove the armature and press it out as I've already said, the bumper is easy enough to remove and then only a few bolts hold the armature on
Post #80907 13th Sep 2011 3:08pm
Andy
My detachable towbar won't come out. If I turn the plastic knob, it goes loose but won't actually detach. I just unbolt it from the square section now and use the square blanking grommet when not in use. A pin would be better than a bolt though 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #85040 2nd Oct 2011 7:03pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Have you tried to turn and pull the knob away from the tow bar?
Gone - Range Rover Supercharged 2006
Post #85045 2nd Oct 2011 7:36pm
Page 3 of 3 <123
