Home > Technical (L322) > wheel |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35248 |
when you start the range the steering wheel should go to a pre-set position, when you switch of the engine the steering wheel should re-tract and go up ..
10th Sep 2011 10:36am |
tolley Member Since: 29 Aug 2011 Location: gloucester Posts: 99 |
thanks scarey
10th Sep 2011 12:34pm |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
Losing the steering wheel up and down movement is quite common, try using the search facility on this forum to find out what's involved in repairing it.
10th Sep 2011 12:40pm |
yes it might be costly to fix,tryed the height when stationary but no joy so that might need fixing. |
10th Sep 2011 1:43pm |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 |
Mine had the same problem but I got it fixed under warranty. Garage said it cost em 900quid for the part they needed to fix it FFRR TD6 HSE
10th Sep 2011 4:09pm |
I THINK I MIGHT GIVE THIS ONE A MISS |
10th Sep 2011 4:20pm |
Or if the car is being sold by a garage either get them to fix it or ask for money off so you can fix it. FFRR TD6 HSE
10th Sep 2011 4:40pm |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
Sounds way over priced for an 04 anyway, I'd either go for a facelift for maybe a little more money, or look at 02 onwards, probably one or two good ones advertised on here! Range Rover-less at the moment - Pining! |
10th Sep 2011 4:41pm |
Do you think so i thought it was not to bad.
10th Sep 2011 5:03pm |
just found another 04 69th 13800 vogue FSH landrover.
10th Sep 2011 5:06pm |
Well as a guide I paid £12900 for my 05 pre-facelift td6 vogue with 125k on the clock, and full lrsh. Fair enough the boot smelled of dog, still does a little until I steam clean it, and the lower tailgate wiring and solenoids were shot but it just takes good hunting down, specially as I don'tind doing a bit of work to get it A1 again |
10th Sep 2011 8:28pm |
Lower miles will mean a higher price FFRR TD6 HSE
10th Sep 2011 9:10pm |
