Home > Technical (L322) > Cheapest L322 EAS fault code reader?
Stebo
2003 Range Rover Vogue 4.4 V8 Giverny Green
As in the title really.
I've found this - http://www.roverreset.com/index.php?option...;Itemid=77
and want to know if there is anything out there cheaper or better that will clear faults with the EAS system.
I currently have a pinhole leak that is only a leak when on off-road mode. Getting sick of having to get somebody to clear the code every two weeks.
Has anybody got the above? Any good?
All help appreciated!
Post #8007 23rd Oct 2009 2:50pm
dan_uk_1984
The EAS ECU is very resilient. Once you have replaced the bag the fault should clear? And no, I've not seen one cheaper than that so far Smile
Dan
Post #8013 23rd Oct 2009 3:18pm
Stebo
Just to let you all know. I bought that "EAS Activate" and it is great. I have played about with diag stuff on cars before but this is so simple and so effective it's brilliant.
Does all you really want it to do, stick it in and it clears the fault, no cables, no laptop, etc.
I've a pinhole leak in my front right strut which although I am going to replace, I'd prefere to wait until after Christmas and considering that the EAS only flags up a problem once every couple of weeks this is perfect.
Well chuffed with it Thumbs Up
Post #8320 9th Nov 2009 10:19am
