I'm no expert on TDV8's, being an S/C owner, however from what I've read, I wouldn't worry too much about the mileage, in fact a car which has done more motorway miles might be a better bet than one which has pottered around locally, and it will certainly be better value.
I guess it depends how long you're going to keep it, and how many miles you will be doing. If it's going to be a car you'll keep long term, then forget about mileage.
I would focus purely on getting the car you want in as good condition as possible, and maybe look at getting Land Rover Approved Used.
Also, depending on the exact spec you want, maybe consider an HSE. Many people automatically discount them, but when you look at the exact spec on an HSE, it may have everything you want, and just provide bette value.
Just noticed you're looking for a Vogue SE, so I guess spec is pretty important to you, which to me would indicate that you need to be realistic about your budget, and if you're going for spec, be prepared to buy a higher mileage car. 80k on one of these is just run in! So go on spec, condition, maybe warranty etc.
Edit, just did a quick search, how about this one, 67k for under £25k
http://www.autotrader.co.uk/classified/adv...?logcode=p
Or if you really want low mileage, how about this one, would need some hard haggling but only 39k miles:
http://www.autotrader.co.uk/classified/adv...?logcode=p 2012 SDV8 Vogue SE
