![]() | Home > Technical (L322) > water shedder |
LOL. You're a funny man. ![]() |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
Has anyone got a picture of one fitted? Does it just go down the back or kind of sit on top of everything? Reformed |
If it sheds water it will sit over the top and 'shed' the water
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
I have had one of these sitting in my garage.
Interesting thing is if you have a water leak and it "sheds" water, where does it shed the water to and how much water can it shed before the pool on the floor starts to cause problems with evaporation etc which then collects under the "water shedder" and then drips down on the bits you were trying to protect in the first place. |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
It's not really possible to take a photo, as it's almost entirely hidden behind all the infotainment boxes. To fit it, you need to remove all the boxes as if removing the tv tuner. 1. Take out the spare cover from the boot 2. Take out the plastic AV floor cover on the LHS this will give you better access to the all the AV equipment 3. Remove the key from the ignition and wait for 2 mins. 4. Prepare to remove everything, you HAVE to take the whole thing out to get at the mounting bolts. 5. Remove the mounting bolts as discussed here: http://files.me.com/stevegt/rql3cm (this was a life saver). 6. You'll be able to disconnect some of the modules and remove. Put them to one side somewhere safe. 7. Lift the frame out and everything still attached in one go. To do this you'll have to unplug it all. Don't be afraid at this point it will all go back together (as long as you get the plugs in the right places). Then you can fit the shredder, it should be obvious how it fits when you have everything out. Start to finish should taken between 1 and 2 hours to do yourself. Good luck. ![]() Gone - Range Rover Supercharged 2006 ![]() |
10mm drill through the floor and a black bin bag will also work |
Thanks Justin
L322Pilot Member Since: 10 Feb 2011 Location: Solihull Posts: 19 ![]() ![]() ![]() |
Having just paid £2300 for a new quater panel to be fitted and painted I think I know where the water gathered after it leaked in. That said I dont see any damage to the Nav unit. |
EVOeng Member Since: 14 Sep 2011 Location: Surrey Posts: 225 ![]() ![]() ![]() |
L322, so where did the water gather? I want to try and reduce the risk of water ingress.
EVOeng, I was shown inside the rear of the the car with everything stripped out, including the rear bumper removed, and the bottom of the quater panel forms a well like channel where water can just gather.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7878 ![]() ![]() ![]() |
Here you go.......
