![]() | Home > Off Topic > Do I need planning permission or building regs? |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
I've just sold my house in the past few weeks and and had a phone call from my solicitor asking me about a few things. The house was newly built in 2006. I have an integral garage which had the combi boiler with normal up and over garage door. There is a door from hall to garage which is a fire door. My wife wanted to convert the garage to a room properly but as we were planning to leave i didn't want the expense so we went down the route of putting up a stud wall in the garage and boxing in the combi with enough space for the washing machine and tumble drier. The stud wall is of timber construction with a plaster board skin on both sides with insulation between. 2 of the walls are plastered as part of the original build, the second i have plaster boarded and we have put wallpaper up to hide the what we classed as a temp room. My solicitor thinks we may have problems and need to apply for building regs etc? Can anyone advise if this is correct and what do they class as temporary and permanent?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35652 ![]() ![]() |
i've done this in my garage but not plastered..loads of peeps in my estate have done the same to house washing machines etc....in past conversations with these peeps there was no mention of planning or building regs as i and they probably assume that the stud walls are temporary.. |
This was my thought, but the solicitor seems to think different. The buyers know its a temp wall but not sure if that will fly with their solicitors as it could quickly turn into a |
get a sledge hammer and knock it down....problem solved.. |
The wife used to work in a solicitors and I was telling her about your post and according to her you would need planning permission to do so and a completion certificate or knock down the stud wall and put the garage back to the original plans
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
We had a similar issue in 2003 when our buyers solicitor requested the planning permission for a conservatory we built. Normally you don't need planning permission for the size of our conservatory, but for some reason unknown to me, our house deeds stated otherwise.
Ok this sounds like a ball ache. The buyer actually want it like it is it's just my solicitor is preempting an issue. There is still a space infront of the temp wall for storage. The garage door is still there and can still be used. It's like blocking off part of your garage to put a workshop in. Granted noddy is the only one who could put his car in there but it's still possible. Will take some pics tomorrow to see if it helps. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Speak to the buyer and just put a clause in the contract of sale stating that they know and accept there is no planning and permisson for the room but it can be applied for before you leave but may not clear in time for the sale and that they accept this risk.
I doubt you would need planning approval as you haven't altered the appearance of the garage externally and what you have done would constitute "permitted development". I didn't need it when I fully converted a double garage to a studio but left the external door in place for appearance sake.
You might be able to get a letter of comfort from the planning department |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2052 ![]() ![]() |
Change of use, therefore planning req.
Rolo Member Since: 11 May 2011 Location: UK Posts: 852 ![]() ![]() ![]() |
Planning permission shouldn;t be needed, but probably building regs - checkout planningportal.gov.uk
Sammyg1413 Member Since: 02 Oct 2011 Location: North west Posts: 16 ![]() ![]() |
Hi I just noticed this post whilst looking for 2003-2006 conversion. I am a qualified solicitor and used to work in conveyancing. I've not had chance to read all the posts but easiest thing to do is ask for indemnity for the lack of building regs, its not expensive and most lenders/solicitors are happy with it. PM if u need any advice |
