![]() | Home > In Car Electronics (L322) > L322 2004 DVD Nav upgrade - MK3 MK4 |
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 ![]() ![]() ![]() |
e.g. can I fit this
http://www.soundmasterscotland.com/denso_l...20508.aspx
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35533 ![]() ![]() |
if you have a touch screen then the only thing you can upgrade is the dvd disc to a newer one... |
lol scarey im really starting to hate having the touch screen model. is there any point in upgrading to a newer disc ? |
the 2009/2010 disc obviously gives you newer mapping and upgrades the nav firmware ..there is also a 2011 disc which only gives you newer maps.. |
Will this visually look better ? |
tbh i cant remember what the visual improvements were when i upgraded mine but there were some... |
any idea on cost or where to by from except for stealers ? |
pm sent.. |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1035 ![]() ![]() |
Why it's the best system? I'm sure all the owners of the Mk iV system would gladly swap with you if it was compatible! 2012 SDV8 Vogue SE |
really ? why is that ? My remark was really down the fact that any sort of upgrade is very limited quite shocked to here the newer mk4 model is even worse. |
The mark 3 models date back to the 90's. The mark 4's were early 2000's, the touch screen was introduced in 2005, and is still not bad for factory fit satnav. I've never felt a need to upgrade it. I don't think Land Rover did until 2010, however this unit would certainly not be compatible with our cars. 2012 SDV8 Vogue SE |
trafpol Member Since: 15 Jun 2011 Location: Surrey Posts: 141 ![]() ![]() ![]() |
What I found was that when you upgrade the Sat Nav disc and the firmware auto updates you lose ability to input destination on the move. I believe it has to be reset at dealers. |
