![]() | Home > General > Fitting towball |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2050 ![]() ![]() |
Are you trying with the key in or out? |
With the key in or out the result is the same. Also the key doesn't seem to lock anything or could it be the towball has to be engaged before this happens? |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
The wheel has to be 'cocked' before it will engage. Turn it round until it locks in place, then push into the receiver. I can't remember if you have to pull it out at the same time as turning it but no doubt someone else will remember. |
Give the man a coconut ![]() Now all working correctly, I can take my trailer load of rubbish to the tip now. Thanks for your help ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35507 ![]() ![]() |
not one of landrovers best ideas ,but it does work... |
