![]() | Home > Technical (L322) > How do I enable "lazy locking" please? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Think you still need a dealer to do it via the OBD Discovery 4 HSE
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 ![]() ![]() ![]() |
Yes, on 2007MY to 2009 MY, all those settings must be made by the dealer.
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2049 ![]() ![]() |
Other forum?
jayzee Member Since: 14 Oct 2009 Location: UK Posts: 342 ![]() ![]() |
Definitely through the OBD - are you sure?
RRV Member Since: 05 Oct 2009 Location: Midlands Posts: 648 ![]() ![]() ![]() |
Does anyone have any idea?I must be able to do a setting of some sort?
nopes.......You're pretty stuck. All you can change is what you see, clock, reset odometer, central screen menus, etc... All those other things, lazy locking, single point entry, autodoor locks on the move, PDC sound level, headlamp timer, low outside temperature warning, key/seat memory activation, etc... must be set by the dealer or someone with the software to ''read'' the car. |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
You can however do the headlamp timer yourself (by following the info on another thread on this forum). I did it on mine , so now, if I want the lights on long enough for me to get in the house, I simply flash the lights and the 'main beam delay' message now appears on my dash display (previously, they just flashed and went straight out as usual) and the lights stay on for a pre-defined time period. |
