Home > Technical (L322) > Lost 4th and 5th gear |
I had the same whilst driving "enthusiastically" back from Wales with lots of manual shifting. Basically the gearbox overheated and it wouldn’t go over 3rd gear for about 10 minutes until it had cooled down.
21st Sep 2009 1:26pm |
saxrom Member Since: 13 Dec 2008 Location: Grays Essex Posts: 23 |
Cheers for that Dan a friend of mine has a workshop and also the same car so it will be done this week he is also doing his as he was under the impression that the box was sealed for life just goes to show you learn something every day |
21st Sep 2009 2:18pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
as dan says change the fluid and strainer and flush the coolent system thru , also check the brakes on your trailer / caravan are releasing properly onto no6 Range Rover
21st Sep 2009 7:47pm |
I drove 100 miles with the handbrake full on on my c'van, didnt even notice (although I did roll my eyes at the single figure mpg) untill I pulled into the service station and saw the smoke! |
21st Sep 2009 10:05pm |
delsilencio Member Since: 08 Apr 2009 Location: toulouse Posts: 116 |
flush gearbox, new filter, new oil and add this one:
25th Sep 2009 5:55pm |
You will need a new car, or a new gearbox at least. Never deviate from recommended fluids in a ZF Gearbox. |
25th Sep 2009 5:57pm |
" You will need a new car, or a new gearbox at least.
17th Oct 2009 12:24pm |
