Home > My Range Rover > New member, for a couple of weeks, best site for FFRR by FAR |
Pauld Member Since: 15 Mar 2010 Location: Sheffield Posts: 199 |
The rear bumper looks all wrong? |
27th Aug 2011 9:57pm |
3R10 Member Since: 17 Oct 2009 Location: Paris Posts: 324 |
Forget that detail! The guy is supercharging it, so I give it props for that! 2000 BMW M5, Avus Blue/LeMans Leather Interior 2006 Range Rover Westminster Java Black |
28th Aug 2011 7:10am |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
he said $6000 not £ "RANGEISM WILL NOT BE TOLERATED" www.futuresecurityservices.co.uk Pretlove says , '' I want my car back " |
29th Aug 2011 12:37pm |
Still a huge amount for customising a non facelift 4.4 V8.
29th Aug 2011 12:48pm |
gaz i agree but still there is a big differance between $6000 and £6000.......i also would just sell it and buy a genuine s/c
29th Aug 2011 12:59pm |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
Plus there's the possibility of it becoming one of those fragile modified cars that you spend more time sorting niggling issues rather than enjoying driving it.
29th Aug 2011 1:23pm |
540i's and 4.4i, X5's with supercharged M62's have been going strong! No problem whatsoever with the gearbox. ESS tuning is one of the most known, respected and reliable supercharger installers on the BMW world, sot I would expect better reliability than an early Jag supercharged engine! I for myself have considered doing this job in the near future, as I want to buy two cars at the same time and it would be much cheaper going the pre-facelift route than the Supercharged version! I know most of you in this forum are purists, but I am waiting like a mad kid for this! If anything goes well, robbo770 might have one of the fastest Range Rovers out there! Definitively faster than a 4.2 SC! 2000 BMW M5, Avus Blue/LeMans Leather Interior 2006 Range Rover Westminster Java Black |
29th Aug 2011 6:24pm |
ive seriously thought about doing it but the cost for me is to much ..............massive hats off if he goes ahead and does it as it will be a beast "RANGEISM WILL NOT BE TOLERATED"
29th Aug 2011 7:01pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3747 |
No way would I spend that on supercharging - its a no brainer. S/H value will be pants. If he wants to keep the car it would be cheaper to turbocharge it - similar results and they are both exactly the same in that they use means of forced induction. One uses engine revs the other exhaust pressure to operate. The only down side can be lag with a turbo, but that can now be virtually extinguished. |
29th Aug 2011 9:30pm |
you may be on to something there vogue but then again theres a lot of work that will need to go into turbo charging i.e new fabricated manifold ....may end up costing around the same "RANGEISM WILL NOT BE TOLERATED"
29th Aug 2011 9:35pm |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 |
Is the 4.4 a Jag or a BMW engine? LR fitted a supercharger to the 4.4V8 RRS with the Jaguar 4.4 and had to insert liners in the cylinders back down to give it 4.2l because they couldn't get any length of service out of the engines due to the thin casting between the cylinders. About 6 were built, one of them ended up at LRE Dunkeld but was supposed to have gone into the crusher.
29th Aug 2011 9:37pm |
Tim, the pre facelift 4.4's are BMW engines, the 2006 facelift are Jag engined, and yes you are 100% right re the liners 4.4 down to 4.2 on the jag supercharged |
29th Aug 2011 9:42pm |
the 4.4 is a bmw engine "RANGEISM WILL NOT BE TOLERATED"
29th Aug 2011 9:43pm |
They also did a 4.4 Jag engine just to confuse matters. The AJ-V8 which was the 4.4 petrol option on the facelift/touch screen cars between 2005/6 to 2009 2006 Mercedes CLS 1991 Retro-style Mini But really finding it hard to fight the urge for a S/C... |
29th Aug 2011 11:08pm |
