Home > Technical (L322) > Laminated Side Glass - Retrofit?
dan_uk_1984
I'd like to fit the laminated side glass to my 2003 RR, I hear this was standard from 2006 onwards (it's meant to keep out more noise). Does anyone know if the glass will physically fit, or if not, what would need changing?
Dan
Post #7743 13th Oct 2009 10:45pm
jayzee
2006 Range Rover Vogue SE Supercharged Java Black
I think you will find that the glass is slightly thicker, so your current seal arrangement would make it all bind - if you are lucky enough to get it to fit in the first place!
Not worth it IMO, as I have noticed very little noise difference between the two.
Post #7767 15th Oct 2009 11:48am
dan_uk_1984
Might knock that idea on the head for now then!
Thanks for the info Thumbs Up
Dan
Post #7771 15th Oct 2009 12:54pm
Agreed, probably not worth the hassle for the perceived benefit. Discovery 4 HSE
Post #7777 15th Oct 2009 1:20pm
