Home > Technical (L322) > ball joint change? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35293 |
used the search scott and found this, hope its what info you need..
26th Aug 2011 12:38pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
Top tip- Get a heavy duty ball joint splitter, will make job so much easier |
26th Aug 2011 2:02pm |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 |
Did both of mine a couple of weeks ago. Jacked the car up undid the ball joint bolt then gave it 2 sharp knocks with a hammer and they were out. You will need a 24mm ring spanner and a 15 or 16mm to separate the inner and outer track rods. Undo the bolt and then count the turns off and then screw the new one on the same number to get a good stab at centre. All in all a quick job, i did both in under 30 mins.
28th Aug 2011 10:12pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
if its ball joints your changing are they the ones with the two holes eigher side of the body for the torx bolts to hold them in if so get a big drift to use for hitting with a hammer and a blow lamp for heating the hub up as when i did mine they were siezed in and i had to destroy them to get out furtunnatley the come out from the bottom when you remove the two torx bolts onto no6 Range Rover
30th Aug 2011 9:51am |
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 |
I have sussed that the awful squeaking from the rear right suspension is due at least in part to the lower hub bush allows about an inch and a half play with the wheel off! Though I think some of the squeak is coming from the bushes between upper wishbone and the body too because of this waggling.
3rd Jun 2012 6:16pm |
