Home > Technical (L322) > Dripping "water" from near gearbox after run with
External temp 20 degrees C, internal temp set at 22 degrees C. About an hour and a half run but only 50 miles due to traffic. Parked up in a Tescos for supplies. On return noticed damp patch under gearbox (could see a slow drip from that area) so moved FFRR to investigate. Smelt and tasted (yeah!) like water.
Is this normal in so much as it is a result of running the air con? No sign of coolant loss. Question .
Post #76765 19th Aug 2011 5:45pm
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Quite normal 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #76766 19th Aug 2011 5:47pm
Its the aircon doing its dehumidity bit and the result is left behind Smile
Post #76768 19th Aug 2011 5:50pm
pretlove
what they said Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #76773 19th Aug 2011 6:31pm
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
Yep, mines always doing it. Air con doing it's job. I call it a Dan drip after Dans love for having the air con on Wink FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #76777 19th Aug 2011 6:39pm
''dan drip'.... Rolling with laughter
Post #76778 19th Aug 2011 6:40pm
GregP
Yeah, I'm sure he'll love it when he reads this Razz FFRR TD6 HSE
Post #76779 19th Aug 2011 7:13pm
dan_uk_1984
Love it, indeed I do!
All that water would othehrwise be wreaking havoc with your electrics, making your leather sticky(rotten over time) and making you sweat more.
Leave it on all year round for clear windows
Post #76782 19th Aug 2011 7:48pm
Thanks all, never spotted it before as I usually park on gravel. .
Post #76811 20th Aug 2011 12:50am
DaveAngel
2015 Range Rover Vogue SE SDV8 Barolo Black
Re: Dripping "water" from near gearbox after run w
This reminds me of a story when a freind of mine was a saftey engineer.
he was doing an assessment on a truck that had a glider launch winch at HMS Dadelus in hampshire. He was driven down to the end of the runway by a 20 something spotty RAF tech, got out and started his inspection.
He noticed there was a liquid on the winch gear, and suspecting it was a leek. Not being able to locate its source of the leek did the 'touch and taste test' to see if it was indeed oil.
at this point he noticed the RAF tech smirking, when he enquired why, the irk replyed
"Well, thats not a leek, you see when we are down this end of the runway, its a long way to the gents.."
True story. __________________
2015 FFRR SDV8
2011 FFRR TDV8 4.4 - Gone
2005 FFRR TDV6 - Gone
Post #77412 24th Aug 2011 9:45am
Nice Smile
Always smell first, then touch, then taste Wink .
Post #77428 24th Aug 2011 12:38pm
