Home > Technical (L322) > Door Locks and SatNav Issue
neilmcm1975
United Kingdom 2002 Range Rover Vogue Td6 Zambezi Silver
Hi this is my first post , I have had my 02 Range Rover Vogue since January and a few months my door handle cable snapped on the drivers door , I purchased one and replaced it but the central locking wouldn't open/close this door, but was fine using the normal key and all the rest were opening and closing with the key . A few weeks back the back passenger stopped opening and closing with the key as well and we have to open the door from the inside . Does anyone have any ideas , I have tried resetting the keys but this doesn't appear to make any difference . I have also had another problem which is the sat/nav stereo is switching itself off and on , sometimes no screen with sound , sometimes nothing at all and sometimes the screen comes on a different colour with no sound .
Thanks Neil
Post #76668 18th Aug 2011 6:20pm
dan_uk_1984
Have you checked your spare wheel well for water? Any water in that area means your nav unit may have got wet at some point. Are you still running the old Mk3 nav or have you done the mk4 upgrade?
Do you leave the A/C on all the time? The climate control is designed to remove excess moisture from the air - this protects all of the electronic modules... Without it, electrical gremlins will ensue. On a humid day the system can remove about 1L of water per hour that would otherwise settle on any cold surface.
As for your door issue, I've found removing and re-fitting the door card can help as it re-syncs the door modules. Also with the door card off, but still plugged in, see if the lock works then? The remote locking is very sensitive to anything touching the sill lock rod. It tries to lock but then bounces back.
Post #76669 18th Aug 2011 6:28pm
neilmcm1975
Thanks had a quick look and found water in the spare wheel well , it's the mk3 system I have , any ideas where to start looking for where the water is coming in.
cheers neil
Post #76678 18th Aug 2011 7:43pm
dan_uk_1984
It tends to make its way in around the near side rear window due to a poor seal.
LR's fix is rather shocking. Do a search Smile
In the mean time, leave your ac on to ensure everything dries out!
Post #76683 18th Aug 2011 8:08pm
neilmcm1975
had a quick look can't see anything could you send me a link to the fix .
cheers neil
Post #76686 18th Aug 2011 8:22pm
the info you need neil is in the wiki..... http://www.fullfatrr.com/wiki/Rear_Water_Ingress
loads of info there and in the forum itself, have a good browse ..
Post #76688 18th Aug 2011 8:24pm
neilmcm1975
Got the water leak fixed it was coming from the boot seal and running down the pillar , new seal fixed it also fitted the water shedder/bag. The front door is now fixed not sure how but had the door card off and was looking for anything obvious put the door back together and it started opening and closing with the key .
The one problem I have left is the rear passenger door is not opening with the keyfob but when its open it shuts with the keyfob has anyone any ideas what to have a look for.
Cheers Neil
Post #84080 27th Sep 2011 8:25am
whip the door card off that one as well neil, might be a loose connection.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #84105 27th Sep 2011 9:26am
