Home > Technical (L322) > Flat Batt - Any experience of Jump Packs ?
TugRR
Calling International Rescue . . .
Currently on hols in Italy Cool - however, RR isn't having as good a time as us, and so has thrown a strop - probably flat batt . . . . .
Waiting for breakdown to come to jump it, then have a drive around.
Question is this - If it's going to do this agin before we're back in UK - is it worth buying a jump pack as a "Get You Home" ?
If so, what spec ie. amps etc ?
Car is a 2005 TD6 - new battery January this year.
Presume I've done it by opening closing roof / windows whilst parked . . . .
Ciao . . . . Where do you go after one of these . . . ?
Post #76166 14th Aug 2011 11:45am
JW911
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
The battery failed (totally) in mine a couple of years ago to the extent that the electric steering lock would not work, so it was stuck in Park. The RAC guy turned up, applied his jump pack and there was only enough juice in it to allow us to unlock the transmission, get it into neutral and push it out of the garage so it could be jump-started from his van.
Their jump packs don't have the power to crank a V8 so I'd be surprised if there were any out there which did. They may work on the TD6 but no guarantees. If I were you, I'd hunt for a new battery while I was out there. 2012 4.4 TDV8 Westminster
2007 3.6 TDV8 Vogue - gone!
2003 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #76168 14th Aug 2011 12:09pm
There's not much power in the £50 consumer ones - they offer a bit of boost but will not help if the battery is properly dead.
Spare battery and a set of jump leads is about the only reliable option - but again you need decent jump leads to handle the required current.
I found machine mart the best source for quality leads at a reasonable price
Post #76175 14th Aug 2011 12:34pm
I've got one of those jump packs which i have used successfully on a number of cars over the years including a 300tdi Discovery in the middle of winter.
Had a flat battery on the td6 a few weeks ago, the jump pack didn't even look at it although fully charged.
I would say your best bet would be to get the car started and then go buy a battery charger and charge your battery. Even if it means taking it off the car.
Bear in mind one of these batteries could take upto 48 hours to charge fully from flat.
Enjoy the rest of your holiday Very Happy
Post #76176 14th Aug 2011 12:43pm
dan_uk_1984
I bought a cheap one off of the bay - about £30. It started my 4.4 a couple of times when the battery was low (from leaving interior lights on etc) and also started it from completely flat once (2 days of interior light on!) But was slow to turn over, if it had been winter I doubt it would have worked.
A lot of time the battery is just too low to crank, but isn't flat and just a little boost is needed. I never needed it after my second battery install Thumbs Up
Post #76182 14th Aug 2011 1:37pm
swast4
My Dad bought me a cheapish Batt pack but it is a bit crappy and no good for my Rangey, it is good for providing power through a cigerette lighter socket or using the built in air pump but thats about it.
Did you leave the car in the access mode position when you left it on Holiday as I'm sure if it isn't it wakes up now and again to check the air suspension is level (can't be 100% about this).
I've always had a problem with my battery (for 4 years of ownership )because if I am in and out of the car a dozen times in an afternoon the battery will be flat and will need jumping (or just 10mins on the charger). But if I park it up for a 2 week holiday it is happy to start on my return even in the winter months. Very strange but have lived with it.
Adam
Post #76185 14th Aug 2011 2:03pm
how about one of those solar battery charger things you can leave on the dash and it'll keep your existing battery topped up..
edit..must learn grammer..
Post #76198 14th Aug 2011 3:32pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
scarey wrote:
how about one of those solar battery charger things you can leave on the dash and it'll your existing battery topped up..
Use one every time I go to work, leave the car for 3 months and it starts first press of the starter button - even after sitting on the drive from October to February last winter the battery was good. They don't need sunshine either as my car spent weeks under a covering of snow and according to reports my father could see the LED that indicates that the battery is charging was still visible winking away. I also plug it into the boot socket which IIRC remains live even when the ignition is off 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #76202 14th Aug 2011 3:52pm
TugRR
Thanks all for your prompt replies Bow down
Europe Assistance attended very promptly - remember, Italy, Sunday afternoon (!)
Charging OK
Started fine off jump pack
Appears ok now
I believe the fault may have been human error ie getting stuff in/out of car, opening/closing windows & doors & sunroof, and blowing up air beds from boot socket - all while engine off . . . . . Rolling Eyes
Plan now is to but HD jump leads or look for jump pack - we'll see . . . .
On a different thread, can the boot lights be disabled ? The interior ones can be de activated following the hand book, but can't see anything for the boot ones . . . . And another thing - what about the ridiculous song and dance the steering has to go through every time you get in it Evil or Very Mad
Thanks again Wink Where do you go after one of these . . . ?
Post #76210 14th Aug 2011 5:38pm
temporally take bulbs out of boot lights ..
Post #76216 14th Aug 2011 5:51pm
TugRR
PHEW - started no probs this AM, then completed 412 miles no probs "and all was good in the world"
I blame the air bed . . . . and it was flat in the AM ! DOH Rolling Eyes
Going for a solar trickle charger when I get back . . . . . where do you get one from ? Where do you go after one of these . . . ?
Post #76334 15th Aug 2011 7:31pm
nbunney
Maplins Thumbs Up
Post #76342 15th Aug 2011 7:58pm
pretlove
i just carry a spare battery and very heavy duty jump leads Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #76347 15th Aug 2011 8:04pm
JW911
+1 for taking out the bulbs. If a door is left open, the interior lights automatically switch off after 45 (??) mins to preserve the battery.
Set the steering wheel as far back into the dashboard as it will go. Then move your seat forwards to the appropriate position and set the seat memory. The steering wheel won't move then. You will end up with a bit less knee room (I'm 6'1" and it's no problem) but it will save you lunching the steering wheel motor as they do have an annoying tendency to break. 2012 4.4 TDV8 Westminster
Post #76371 15th Aug 2011 8:46pm
Paul J.
I have one of these in my boot:
http://www.halfords.com/webapp/wcs/stores/...yId_165629
Paul
Post #76374 15th Aug 2011 9:04pm
