Home > Technical (L322) > Coolant Loss
Nod 1
United Kingdom 2010 Range Rover Autobiography Black 5.0 SC V8 Santorini Black
Coolant Loss
Got a strange one..! Suddenly today, The Bong warning came on saying check coolant level. Checked it and had to put a litre in. Drove car all day and no further warning. Went out late afternoon and when returning to car noticed puddle beneath expansion tank on floor. Warning cam on again, had to then put about half liter in. Could not see where leak coming from. Arrived home and filed to proper level and left car running. All fans were working and no leak..!
Decided to drive car up road and back and warning came back on. Back on drive, I gingerly undid filler cap and there was not a great deal of pressure, then alot of rumbling and gushing of fluid from filler cap. Checked oil filer cap no sludge and no crud round coolant filler cap.
I have read alot about sensors and problems with expansion tanks.
Car is 2002 L322 which has been lavised regularly. Also new radiatior and viscous fan about 3 months ago.
Has anyone got any suggestions please.
Cheers in advance
Post #75952 12th Aug 2011 7:07pm
stu
has the expansion tank cap given up the ghost? do these not have pressure valves built into them?
i am sure someone will be along soon with all the answers to your questions.
hope you get sorted out soon. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #75966 12th Aug 2011 8:37pm
Nod 1
I hope so. Thanks for your response
Post #75975 12th Aug 2011 9:16pm
pretlove
sounds like the cap what number is on your expansion cap? "RANGEISM WILL NOT BE TOLERATED"
Post #75997 12th Aug 2011 10:21pm
Nod 1
Just checked and it is 200. I am just off to get cap, expansion box and sensor. Will let you know later
Post #76019 13th Aug 2011 7:38am
If you are getting a puddle under the car that's a good thing. If you were loosing it and didn't know where it could have been a HGF. But yours sounds quite easy to sort. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #76026 13th Aug 2011 8:40am
Nod 1
Just been and got cap and it has 140 stamped on it. Queried it with the Parts guy and he said it was correct one. Anyone any ideas why the change from 200 to 140 ?
Post #76038 13th Aug 2011 9:55am
as far as i can remember , the 200 is for petrol and 140 is for diesels.....
enter "coolant loss" into the search [with quotation marks]
Post #76040 13th Aug 2011 10:01am
pretlove
i thought the v8 petrol was meant to be 200 ....as if i remember right someone else had this problem before and theres was due to the incorrect cap "RANGEISM WILL NOT BE TOLERATED"
Post #76042 13th Aug 2011 10:13am
If yours is a petrol and you put a 140 on you WILL loose water. The petrol system is pressurised higher than the diesel. This was covered a few months back. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #76046 13th Aug 2011 10:34am
and maybe this is why the coolant is more prone to being lost..
Post #76048 13th Aug 2011 10:52am
Nod 1
The original I took off had 200 stamped on it. The one i was given by Lancasters had 140 stamped on it. I have just queried this with them and they say there is only one part number....! Any suggestions please
Post #76049 13th Aug 2011 11:00am
they have given you the wrong part...i'd go somewhere else..
Post #76050 13th Aug 2011 11:04am
pretlove
they sell the caps on fleebay just give them theres back and get one from there "RANGEISM WILL NOT BE TOLERATED"
Post #76052 13th Aug 2011 11:32am
I would put money on it! Any little gap and it comes out. Think that's why BMW designed the stupid hose's with the stupid clips instead of jubilee clips. If the caps are anything to go by there jet be quite a difference. 140psi(9.5bar) compared to 200psi(13bar). Obviously these are the relief pressures but it's a big difference [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #76057 13th Aug 2011 11:46am
