Home > Technical (L322) > Td6 cutting out |
Which fuel pump did you change? |
10th Aug 2011 2:56pm |
ben2012 Member Since: 10 Jan 2011 Location: West Yorkshire Posts: 54 |
it was one at the rear of the car not 100% sure but i know it didnt take long to change, it just seems strange how it works fine then all of a sudden stops! |
10th Aug 2011 8:25pm |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
How steep was the hill and how much fuel was in the car? No longer FF owner but still interested. Present car Jaguar XE
10th Aug 2011 8:28pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Might be wrong but i think diesel's have 2 fuel pumps. A low pressure and a high pressure. Think the one in the boot is the low and then somewhere else is the HP for supplying the cyclinders. that might be the one causing the problems? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
10th Aug 2011 8:31pm |
it wasnt that steep and if anything it was leveling out when it cut out, their was probably about halfway between empty and a quarter of diesel |
10th Aug 2011 8:32pm |
Page 153 of the workshop manual. if you dont have it there is a link in the wiki. sorry dont know how to attach the pdf image
10th Aug 2011 8:38pm |
Just a thought, as a faulty low pressure pump would likely show up if the fuel level was quite low. One pump moves the fuel from the tank to the engine area. The other pump squirts the fuel into the engine. Old Discoveries used to have a very noisy mechanical lift pump. I spent many years listening to that racket No longer FF owner but still interested. Present car Jaguar XE ............................................ Previous car Td6 SE ................................ Previous LR- Disco 300TDi Auto |
10th Aug 2011 8:45pm |
Check the diesel cooler in the engine bay is free from muck and leaves |
10th Aug 2011 8:46pm |
just been looking at the workshop manual link posted earlier, and i think the secondary fuel pump was the one replaced, which is the other pump you suggest i look at? and how do you clean the fuel cooler?
10th Aug 2011 9:01pm |
The other fuel pump is in the fuel tank.
10th Aug 2011 9:11pm |
