Home > Off Topic > 4.4 supercharged
pretlove
4.4 supercharged
after browsing the net for s/c ff I mistakebly put in 4.4 instead of 4.2 and came back with this
http://www.beastpower.com/p/bmw/ess-vt1/ES-SC-108-82HB
this one works out around Ł4,300 "RANGEISM WILL NOT BE TOLERATED"
Post #75548 10th Aug 2011 7:31pm
not genned up on engines but i think that might be the wrong one for a fullfat....
Post #75549 10th Aug 2011 7:33pm
pretlove
ok and theres this from arden which is for the ff 4.4 v8
oh and its only 500bhp Shocked "RANGEISM WILL NOT BE TOLERATED"
Post #75551 10th Aug 2011 7:42pm
pretlove
there was a company called Special Vehicle Concepts that did tunning and a supercharger kit for the 4.4 but they have disapeared off the net "RANGEISM WILL NOT BE TOLERATED"
Post #75553 10th Aug 2011 7:49pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Actually there was a batch of RRSports built with 4.4S/C engines - about six of them. One of them ended up at the Dunkeld LRE
for a few years, rescued from the Solihull crusher. It wasn't put into production as a 4.4 as they found engine longevity wasn't great. it was sleeved down to the 4.2 with thicker liners in the cylinders (or something like that). 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #75560 10th Aug 2011 8:52pm
Where do i sign????????? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #75562 10th Aug 2011 8:59pm
allycraven
Next to the mortgage papers you'll need to afford it!!![/quote]
Post #75563 10th Aug 2011 9:16pm
robbo770
Scotland 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Hi Guys,
the arden is based on the 4.2 AJ Jaguar engine only and costs a bomb!!!
the other entry is correct there was a very elite number of RRS with a SC on the M62 engine, but as the write states the piston barrels get hammered which totals the block, hence the bore out and liners to 4.2 ltrs.
thenm the BMW engine was replaced to the Jag and all hope was lost of a monster.
The link is actual correct scarey, but your as well to go to vortex in the USA direct.
I have fuill coversion details if required via PM and email for all interested.
just don't have the cash to do it, with exhaust and kit 500 HP is possible, but gearbox needs to be new and wont last if punished!!!, you have been warned
Rob Current vehicles
4.2 SC FFRR RSE 2010- facelift
Range Rover Evogue Dynamic Lux
Gone
Rejected RRS my14.5 nightmare
Disco B4 XXV convert
Freelander 06 SE
06 RFFRR 4.2 SC Vogue RSE
Audi A8 4.2Tdi Quattro (hated with a vengence!!)
54 FFRR 2005 model V8 4.4 Cobra Variant
53 Mitsubishi Shogun V6
Post #75567 10th Aug 2011 9:28pm
pretlove
the arden engine above was advertised as a 4.4 range rover ....maybe they got there wires crossed ....rob would you pm me the details Thumbs Up if only to window shop
this is what it says on the website
Range Rover 4.4 liter V8:
Arden performance, a German tuning company specializing in luxury performance vehicles have developed a complete performance package for your Range Rover V8.
The package includes:
1- An engine rebuild kit including:
a. Stroker crank bringing up the displacement to 4.8 litres
b. Lower compression 9:1 pistons
2- Complete supercharger package
3- intercooler
4- ECU reprogramming
The kit produces an astounding 500 hp @ 6250rpms and 516 ft.lbs of torque @ 4250 rpms. This is capable of accelerating the vehicle from 0-60mph in a short time of 6.5 seconds.
Performance can further be improved using Arden designed ‘off road only’ performance headers and high flow cats. Furthermore, a high flow exhaust system is available jointly through Arden / Meisterschaft "RANGEISM WILL NOT BE TOLERATED"
Post #75588 10th Aug 2011 11:04pm
pretlove
rob i think you may be right as another website say this
http://www.lro.com/news.php?sid=206
and this is the website that made me think it was for the 4.4
http://www.superchargerperformance.com/sup...ange-rover Big Cry Big Cry "RANGEISM WILL NOT BE TOLERATED"
Post #75589 10th Aug 2011 11:13pm
robbo770
Not to be bashful but I know I am, I contacted them and vortex in the USA last year as I was going to drive to Germany to have it done. Hence it is not a M62 engine but an AJ, look at the belt arrangement and the alternator
It is not water cooled... Thumbs Up Current vehicles
Gone
Freelander 06 SE
Post #75590 10th Aug 2011 11:19pm
pretlove
Big Cry Big Cry it gets worse the first company i mentioned (Special Vehicle Concepts) well the owner has died apparently and that is why the website has vanished as have the contact numbers......
and rob after looking closer at the pic im a little embarrassed to say its bloody obvious its the 4.2 jag engine Embarassed "RANGEISM WILL NOT BE TOLERATED"
Post #75591 10th Aug 2011 11:25pm
robbo770
well i have decided, because i got a steal of a price on a complete supercharger!! to build my own kit together!!
here is the Supercharger 3rd Generation M90 Eaton unit
I then secured a intercooler, this may have to change as there is not much room at the front of the M62 4.4 radiator and bumper!!,
so I have look at where this bad Boy M90 unit will fit and the rotation is right for it at the right hand side from the front of the car, so with a fabricated mounting over the cylinder head cover at that side it could with a purchase of the Vortech bottom pulley and fan drive extention, be driven with its own belt and tensioner, but some guarding will be required and belt protection for hoses.
here the image of under the bonnet!
Think might have to go for a water cooled intercooler than can fit either above the sceen washer tank, or a swap below in that location could be done, but there is available an air duct zone above to route force air around what ever intercooler I decide on.
I need to custom source an intake spout for the M90 which will on the output has to have a max 6-7PSI bypass with pressure activation on the outlet, thus if I throttle back the supercharger just recycles the air till feed automatically decreases the built pressure and the bypass closes, therefore no lag always charge available when required!! may even be able to use a turbo system here too allow a nice in car Pressure gauge.
Will keep you advised as I progress, but am waiting on full supercharger service kit so its all new when fitted.
may need forum help to get brackets made and maybe if a map ends up being needed, but 6-7 PSI should be okay with standard setup.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Current vehicles
Gone
Freelander 06 SE
Post #79778 7th Sep 2011 8:21pm
pretlove
Bow down Bow down "RANGEISM WILL NOT BE TOLERATED"
Post #79843 8th Sep 2011 2:00pm
now that is a nice clean engine bay... Thumbs Up
Post #79857 8th Sep 2011 3:25pm
