Home > General > 2009 sunroof issue
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
2009 sunroof issue
Hi, After a bit of help for a friend who has a 2009 Westminster. The sunroof when closed now sits slightly lower at the rear edge causing a bit of wind noise. It works ok and does not leak but the wind noise is a bit irritating, is there any adjustments that can be made or is it back to the dealer ? Thanks ! 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #75430 9th Aug 2011 5:52pm
dan_uk_1984
Mine used to do this untill I ran through the "Sunroof Initialisation Procedure"
http://www.fullfatrr.com/forum/topic4017.html?highlight=sunroof
Post #75448 9th Aug 2011 7:20pm
jez000
Thanks Dan, that worked a treat Thumbs Up 2021 P400 Silicon Silver AB
Post #75498 10th Aug 2011 10:09am
