Home > Maintenance & Mods (L322) > Brake Pad Warning
Shaun
England 2011 Range Rover Vogue 4.4 V8 Orkney Grey
Brake Pad Warning
Just found that one of the front wheels has chewed up the wiring to the brake pad sensor. I have yet to replace it yet. Will the warning reset itself or will it require Testbook or similar to reset?
Post #75167 7th Aug 2011 5:51pm
dan_uk_1984
It will reset when you replace the cable & sensor Thumbs Up
Post #75169 7th Aug 2011 5:53pm
pretlove
i had to turn mine off using diagnostic tool "RANGEISM WILL NOT BE TOLERATED"
Post #75172 7th Aug 2011 6:04pm
dan_uk_1984
It takes a couple of ignition cyles, and I always found I had to leave the ign on for about 15 seconds for it to register, but the sensor goes open circuit to give you the warning. When you put a new sensor on and it goes closed circuit the message will go away.
There is no pad wear sensor replacement option in T4 etc... What diagnostics tool did you use to clear it?
Post #75186 7th Aug 2011 6:32pm
pretlove
just a standerd obdII with scan software ...but you may have been right about the ignition cycle as i turned it off as soon as i noticed that it hadnt gone out so didnt give it much of a chance to go out by itself...........a little off topic , ive got an airbag light that needs to be reset any ideas on software i can use to do that or is it gonna be rac, faultmate "RANGEISM WILL NOT BE TOLERATED"
Post #75189 7th Aug 2011 6:34pm
dan_uk_1984
RAC'll do it...
Post #75190 7th Aug 2011 6:36pm
pretlove
am i right in saying you cant just use there software with your own obdII / usb plug "RANGEISM WILL NOT BE TOLERATED"
Post #75191 7th Aug 2011 6:37pm
dan_uk_1984
Correct...
Post #75192 7th Aug 2011 6:39pm
