Home > Technical (L322) > Old Towbar removed - is this OK?
Superspoons
Hi All,
As the Defender tows our trailer, I decided to removed the Tow bar from the FFRR. As you can hopefully see in the pictures the main bar is fixed across the back between the two 'legs' via 2 meaty bolts. I've removed the bolts the main bar has slid out with a bit of effort.
Can I leave the underneath like it is now? Is this structually sound and safe? I may want to reattach it one day, but for now it's going into store.
cheers. Gavin
Post #74238 30th Jul 2011 9:14am
not familiar with this one but it does look like you need something put back in its place...
Post #74240 30th Jul 2011 9:21am
I would suggest mabe disconnecting the electronic cable and maybe putting it all in the shed or garage. In its current state will make a hell of a noise and probably do a lot of damage should you try and drive with it hanging under the car like that @ 70mph. Just a thought. Thumbs Up Rolling with laughter
joking aside i think the 2 legs where the hitch bolts to chasis look different to standard so maybe they have already done the structural stuff before the hitch was fitted. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #74244 30th Jul 2011 9:52am
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Thats a non genuine towbar , but it looks like you are missing the supports that bolt were the brkts you have now go the ones with the tow eye attached have a look at a car with out a tow bar and youll see what i mean onto no6 Range Rover
Everyone needs a hobby
Post #74245 30th Jul 2011 9:55am
heres a pic of my bottom which shows the oe towbar ..obviously you havnt got this but you should have something there in its place..
Post #74246 30th Jul 2011 9:58am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Yeah it's an aftermarket tow bar looks like you've lost the towing eyelet which is by the right hand side and have been replaced with angle iron.
I have the original non towbar side supports from when I fitted the OEM armature but you'd need to drop the back bumper to fit them.
Definitely remove the towing electrics (15 minutes max) and duct tape over both sides of the hole.
As far as I can see there's no additional structure required the exhaust hangers are in place (be pretty obvious if they weren't!) TBF the original straps aren't adding any real strength.
Post #74247 30th Jul 2011 10:03am
Superspoons
Cheers all for the quick reply's.
...yes, I was planning on tucking the electrics up out of the way Laughing
More Pics as it stands now. I think, structurally it's OK as it is, but I will nip it down to my friendly indepentent for him to take a look anyway. It's just the gap in between that now might be an issue... Question
God this iPhone is handy Smile
Cheers Gavin
Post #74251 30th Jul 2011 10:40am
Stephen.125
No problem!
The OEM solution non-towbar doesn't have anything between the two side strips so you should be fine. It's not like I adds any rigidity.
Glad to help. Thumbs Up
Post #74255 30th Jul 2011 11:06am
superspoons , a bit of black metal paint could be an good idea under there...
Post #74258 30th Jul 2011 11:12am
nbunney
Can't see the bumper support / towing eye brackets Whistle
I have a set for sale if you want them Thumbs Up
Post #74262 30th Jul 2011 12:09pm
Superspoons
The bumper is rock solid and I can't see where extra supports would go...The angle iron each side of the tow bar I've just removed are holding the bumper in place
These were in the boot when I bought it -
These are surplus to requirements now that the 2 brackets shown above are in place Question Yes, no eye for strapping down but I could always raid the Defender parts bin and bolt one of those up there Idea
I would like to get hold of a 'proper' quick release one with the swam neck, so if anyone has the bits please let me know.
cheers Gavin
Post #74266 30th Jul 2011 12:55pm
nbunney
Sold my Swan neck, but have the removeable Fixed plate version available Thumbs Up
Post #74273 30th Jul 2011 1:29pm
