![]() | Home > In Car Electronics (L322) > Only Bass speakers appear to be working |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35651 ![]() ![]() |
it could be a menu setting, water in the electronics in the rear or a loose connection..
Jcsh Member Since: 27 Jul 2011 Location: Poitiers Posts: 35 ![]() ![]() |
Removal of the connector atop the amplifier revealed a slight amount of moisture ingress - a bit of green in there but not on the actual spades tehmselves - nevertheless I did a bit of a clean up and reasssembled - No difference. No water in the wheel arch bottom - lots of dust though ! bit surprised about that.
you've done all the obvious things and it does now sound [no pun intended] like the amp..the green on the terminals might indicate that water 'could' have gone into the amp itself.. |
I was afraid you might say that ![]() I've also found on the net that these radio units have a dry joint problem and that you can buy kits to repair them. Has anybody actually done this ? Also, bluapunkt seem to have an amplifier which is reasonably priced that replaces the RR/BMW radio altogether. Anybody done this? |
I'm curious - on the one hand you mention atop the amp so it sounds like you have a factory nav, on the other hand you want to replace the radio altogether with a Blaupunkt unit which sounds more like the MID radio/cd. Which do you have?
Hi Steve, I have the HSE model and from what you have said, I think I probably have the MID (that would be the read-out on the dash??) and the hi-line stereo. I have no nav. The connector I was talking about is a multi connector with a hinge release mechanism. It is on top of the amp to the rear of the vehicle, Amp in the wheel arch.
