Home > General > how to tell build date from vin number
iancollins
England 2016 Range Rover Vogue SDV6 Causeway Grey
anyone any idea how i can tell the build date from the vin number
have new vogue 4.4 tdv8
dealer is telling me it is a 2011.5 and not old stock 2011
just want to check
Post #73653 25th Jul 2011 1:19pm
Fox
The VIN only includes the model year I believe.
Digit 10 If I remember correctly.
Post #73672 25th Jul 2011 2:33pm
HUGI
Switzerland 2006 Range Rover Vogue Supercharged Java Black
when you put the VIN number in Microcat it tells you the buid date
Post #73681 25th Jul 2011 3:11pm
Rolo
United Kingdom 2012 Range Rover Vogue SE TDV8 Orkney Grey
Does it make any difference - is the 2011 not identical to 2011.5 ?
Post #73698 25th Jul 2011 4:59pm
iancollins
dealer tells me they are not the same
battery problems now resolved on 11.5 and new software
Post #73806 26th Jul 2011 12:47pm
Rolo
Are you getting any battery issues with yours ?
I guess software doesn't matter as that will always be upgraded / uploaded as and when needed.....
Are they supposed to be fitting a different type of battery now then ? That may be something to check on yours.
Post #73807 26th Jul 2011 12:49pm
iancollins
have had a couple of issues where have been playing aroung with the satnav or using the tv with the engine off and after 5/7 minutes a message comes up on dashboard saying "low battery please start engine" and headunit goes into standby mode.
the car still starts ok
dealer has checked battery and has said that when they had battery issues on the early 4.4 2011 cars they replaced the battery but also changed the warning paramiters so that the warning comes on earlier before the battery goes flat.
now the new type "fibreglass matting filled" battery is fitted as standard there is new software to increase the battery drain before the warning comes on.
just waiting for LR to issue the software update.
not totally convinced but will be happy to have been proved wrong.
will keep the forum updated.
apart from this i am well pleased with the new 4.4 model Very Happy
Post #73813 26th Jul 2011 2:21pm
Rolo
Thanks for the info & yes, please keep us updated Thumbs Up
Post #73827 26th Jul 2011 3:44pm
