Home > Technical (L322) > Eas fault ? Door lock |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
Hi Bigstu,
24th Jul 2011 3:15pm |
Bigstu Member Since: 24 Jul 2011 Location: Essex Posts: 7 |
Hi, tried that thought it only re calibrated the steering angle sensor but didn't work anyway lol |
24th Jul 2011 3:50pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
sometimes dis-connecting the battery re-sets the ecu's... |
24th Jul 2011 5:03pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
The side door latches incorporate a sensor to provide a door status signal to the BCU.
24th Jul 2011 7:34pm |
that makes a lot of sense ... |
25th Jul 2011 8:45am |
Fitted new door lock only took 5 mins max
26th Jul 2011 5:19pm |
did you do this? |
26th Jul 2011 5:33pm |
Yeh tried it before I replaced the door lock will try it again |
26th Jul 2011 6:21pm |
Didn't work again.
26th Jul 2011 8:25pm |
All sorted went to Fortune 4x4 in laindon to get a code read out compressor overheat codes was all reset and light now off etc
27th Jul 2011 5:10pm |
why did you disconnect the compressor stu? |
27th Jul 2011 5:11pm |
I disconnected the wiring harness in the spare wheel well to check for a live feed and see if I could check the can bus lines etc but I think the ecu shut the system down so didn't get an plausible readings |
27th Jul 2011 5:38pm |
understood. ... |
28th Jul 2011 6:48am |
