Home > Technical (L322) > Alarm going off
duka
2010 Range Rover Autobiography 4.4 V8 Alaska White
Alarm going off
Seem to have the alarm going off for no reason intermittently, but it's not the full blown alarm just indcators flashing and mid-low siren - any clues on where to start looking/checking?
Post #73141 20th Jul 2011 5:41pm
supershuttle
Bonnet Catch - disconnect and if it stops going off bob's your mothers brother! Geoff
Post #73144 20th Jul 2011 6:04pm
swast4
Mine did this the other night in the early hours, reet it and it went off again 20 mins later. Went to put it on the drive and leave un loacked and noticed a Moth, removed Moth and end of problem.
Adam
Post #73168 20th Jul 2011 11:40pm
pretlove
that will be the range rover gremlin thats going out and messing with everyones bonnet switch ...i think its been 3 in the past week "RANGEISM WILL NOT BE TOLERATED"
Post #73171 21st Jul 2011 12:05am
duka
Ok thanks, I take it the switch/sensor is on the landing panel? will have a look today.
Post #73176 21st Jul 2011 6:15am
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
Allow me to be the fourth! Have the same problem so I'll try disconnecting the bonnet switch today..
I guess it's the sun hitting the bonnet and causing the metal to expand Laughing
Post #73200 21st Jul 2011 9:59am
what sun? Very Happy
Post #73202 21st Jul 2011 10:17am
mrd1990
The engine Whistle
Well it's been almost 48 hours and not a peep from the alarm! Use to go off at least once a day so seems fixed. Question is: should I fix the sensor or just leave it unplugged permanently?
Post #73474 23rd Jul 2011 10:35am
Localizer
Me too. LRA assist advise leave it disconnect - mine's off to the dealer for adjustment or replacement on Wednesday.
Post #73551 24th Jul 2011 10:18am
dwillerton
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
And allow me to be the fith! Started going off this morning. Will clean/WD40 the switch and if that doesn't work disconnect it. Wish the stuck CD changer was as simple to fix...
Post #74130 29th Jul 2011 12:36pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
I think I might have this.
Symptoms are:
* Random event
* Car not driven for a few hours
* Beeping begins with hazards flashing (beeping is similar to a lorry reversing)
* Dog goes feckin spastic
* If you don't get to it in time (wake up, wonder wtf, get out of bed, stumble downstairs, blearily find keys), the beeping stops and the hazards continue.
* Stops when you unlock the car on the remote.
Where do I find the bonnet switch?
Post #75318 9th Aug 2011 9:02am
mrd1990
All the way at the top left under the bonnet..
just pull the wire out and make sure it's not hanging down or going to rub against anything
Post #75325 9th Aug 2011 9:35am
dan_uk_1984
Surprised you even need to ask really.
Not withstanding the fact I hate having things not working on the car - you would also invalidate the "theft" part of your insurance as you have disabled part of your security system.
Someone could open your bonnet to disable the alarm and then make off with your car.
Post #75329 9th Aug 2011 9:40am
The Isle of Man had the best idea, the birch.
Nobody ever went back for a second dose apparently.
EU stopped them using it unfortunately.
Post #75331 9th Aug 2011 9:47am
mrd1990
Getting it fixed is at the top of the list
But I guess from a technical point of view, it's not causing any damage?
Post #75343 9th Aug 2011 10:25am
